Author Topic: Max Immelmann's Fokker E.I 13/15 scratch 1/144  (Read 55138 times)
Offline ondra
Re: Max Immelmann's Fokker E.I 13/15 scratch 1/144
« Reply #195 on: January 11, 2018, 02:08:14 AM »
Many thanks for your kind words and support, Rick, Juan and Lance!
I spent the recent days reviewing all parts and planning next steps. Well, I will admit I was not much in mood for modelling, so this is rather sort of excuse to myself. :)
Next up will be the dry fit test using masking fluid to hold parts in place and then there are only 37 steps left to finish her (excluding the base). :)
Hope to post photos of the dry fit test on the weekend.
Ondra
« Reply #196 on: January 11, 2018, 02:52:13 AM »
Good luck with that little puzzle - and don't loose those small parts!
You should not use a vacuum cleaner in your flat until this beauty is finished ;)
« Reply #197 on: January 11, 2018, 03:33:35 AM »
Ondra I can barely see that gun even in the enlarged photos, so how you manage to make it and the sight is beyond my imagination! Mind you your builds are beyond my imagination most of the time! Simply incredible what you achieve - including super oil stains, and a very realistic base.
Offline ondra
« Reply #198 on: January 14, 2018, 11:36:59 PM »
Many thanks for your supportive comments, Frank and Stephen, they are highly appreciated!
This weekend was mainly about playing around with self adhesive aluminium foil, as I had to add the rest of details to the undercarriage. Not the most enjoyable part of the build, I will admit.
I glued the seat in place and added the cockpit coaming.
The wheels got a bit more weathering by means of wash, I will leave them as they are.
Ondra
« Reply #199 on: January 15, 2018, 01:57:13 AM »
The details are absolutely incredible Ondra! I really love the fuselage!
« Reply #200 on: January 15, 2018, 05:30:56 AM »
Ondra,
    I use that self adhesive foil on pipe clamps etc. on 1:32 engines, and often struggle with it, this is just incredible! The landing gear assembly is a work of art, nicely done!
« Reply #201 on: January 15, 2018, 07:37:05 AM »
At this scale, it is all kinds of unbelievable.  Outstanding all-around.
Offline ondra
« Reply #202 on: January 22, 2018, 12:44:52 AM »
Many thanks for your nice words, Rick, Lance and Juan!
This weekend was about assembly test using masking fluid. It was neat to see her stand on her wobbly legs for the first time. :)
The good news: I was able to fix the wrong angle of the undercarriage (once again many thanks for the advice to solder it). On the photos the undercarriage is before the angle correction.
The bad news: I will have to rework the engine, as it does not fit under the cowling. Nevermind, that's life. :)
Ondra
« Last Edit: January 22, 2018, 03:48:37 PM by ondra »
« Reply #203 on: January 22, 2018, 01:42:56 AM »
You are the real master of that scale!
Yes, the higher effort (if any) pays really back later!
Offline jeroen_R90S
« Reply #204 on: January 22, 2018, 02:10:02 AM »
Incredible work Ondra -I hope you get the engine issue sorted out!
« Reply #205 on: January 22, 2018, 04:35:53 AM »
Engines not fittig under cowlings is something I suspect many if not all of us know about - but in rather larger scales! The undercarriage is a mini-gem alone, never mind the rest of this model.
« Reply #206 on: January 22, 2018, 05:09:09 AM »
Just WOW Ondra!
« Reply #207 on: January 22, 2018, 08:40:23 AM »
Ondra you are getting more and more a miracle. This is incredible modelling, simply amazing! I cross my fingers for a good engine fit!
Offline ondra
« Reply #208 on: January 22, 2018, 03:51:54 PM »
Many thanks for your support, Frank, Jeroen, Stephen, Rick and Andreas, it is highly appreciated!
The new engine should not be that hard to create, this time I will be smarter and shorten the cylinders that will be under the cowling. :)
My thoughts now go in the direction of what to do with the current engine - should any of you have an idea how to incorporate it in the base, any suggestions are welcome.
Ondra
« Reply #209 on: January 22, 2018, 04:02:02 PM »
Wonderful, Ondra! Always I drop in to your builds I am more impressed. Hopefully you will solve the engine problem.
Bye,
