Author Topic: WingnutWings Fokker D.VII (Alb) Robert Greim, Jasta 34b  (Read 46172 times)
Re: WingnutWings Fokker D.VII (Alb) Robert Greim, Jasta 34b
« Reply #90 on: April 04, 2018, 10:59:23 PM »
lozenge porn...
« Reply #91 on: April 04, 2018, 11:06:48 PM »
100%!! They look Stormy Daniels awesome...and Im telling everyone!!!!
« Reply #92 on: April 04, 2018, 11:11:28 PM »
Lovely Lozenge application.  Never get too much in the way of photos!
« Reply #93 on: April 05, 2018, 03:45:46 AM »
Ditto !!
Offline jeroen_R90S
« Reply #94 on: April 05, 2018, 04:33:03 PM »
Thanks for the kind words, guys! :) :)
Applying these is going quite well now, I'm doing 2-4 pieces in an evening moment when the kids are in bed, so they are progressing... :)
« Reply #95 on: April 06, 2018, 04:15:57 AM »
 Jeroen,
Excellent decal application my old friend. Keep these wonderful updates coming.
Offline jeroen_R90S
« Reply #96 on: April 26, 2018, 05:13:56 AM »
Thank you, Gregory!
I'm currently more working on my camper van conversion, so not much modelling gets done. I've managed to apply all the lozenge in the meantime, but somehow am not in the right frame of mind to trim the overlaps and find a working way for the wing tips -these have some folds that I don't want to turn into wrinkles by simply slapping decal solvent or something on it.
On top of that my compressor is kaputt, it spits oil/grease through the air line -not good, so I need a new one  :-\ I did have some wierd issues with my airbrush a few times the last weeks, but finding the air hose and air valve of the airbrush in grease isn't helpful I guess...
Jeroen
Offline jeroen_R90S
« Reply #97 on: September 27, 2018, 04:11:56 AM »
So, as it is now dark around 20:30 and my wife has a lot of weekends and evenings to work I've put the van in storage until next april. So after cleaning up the bench and getting a new compressor, I'm back to modelling.
One of my first tasks was finishing the lozenge application on the wings, including trimming and mixing a paint match for the blue rib tapes. I had some slips when cutting the sheet so had a few gaps here and there on the leading edge, as well as the trailing edge after trimming.
The wing tips aren't perfect, but I've managed to make them presentable enough with a bit of touch-up and will overcoat it all later with a brown tinted varnish to tone down the colours a bit and blend my touch-ups in.
I must admit I'm quite proud of the trailing edges, my oil paint mixture was pretty good so it's barely visible (except in daylight at some angles, the decals are gloss and the oils turn matt) about 50% if this is paint.
I also masked off the wheels and went to work masking the propeller -that was quite a frustrating job! In 1/72 you can get away with the overall effect of a few laminations, but in 1/32 it's quite a prominent eye-catcher so I wanted it to look good.
I referred to photo's of other models and of real aircraft, but did not quite get the laminations they way I wanted. In the end, the solution proved simple... (well, not as simple as buying a Proper Plane wood propeller!) If you imagine how the propeller was built from layers of wood and then start at the hub with very thin masking tape strips, just look from the side and mask straight up to above. In my case it's a Niendorf that is straight at the rear when looked from the side, so I used that as a starting point.
The process is probably a lot easer to explain with pictures, but my propeller is now a light wood colour and my 0,5mm masking tape is a paper/linen colour so it's just about invisible...
Hopefully in a few days a new update with more pictures :)
Jeroen
« Reply #98 on: September 29, 2018, 06:03:07 PM »
Those trailing edges look great!  I have an Alb D.VII, and I've been wondering what I'd have to do to get them to look right.
Gaz
Offline jeroen_R90S
« Reply #99 on: October 03, 2018, 05:46:03 PM »
Thanks! :)
By the way, I got the Greim decals through this forum and there are a few extra's left for the factory new 652/18, the red//white striped Jasta 43 machine, and Raesch's pitchfork machine, also of Jasta 43. If you like I can send them to you, as I don't have any more D.VIIs and won't use them you just need to mask off some square crosses.
Jeroen
« Reply #100 on: October 07, 2018, 06:07:54 AM »
Excellent work on the blue taping!
Offline jeroen_R90S
« Reply #101 on: October 10, 2018, 04:51:05 AM »
Thanks, RAGIII :)
I've done the same thing as Lance on his LVG C.VI, I've oversprayed the beautiful Aviattic lozenge decals, but with a drab brown varnish in my case. As much as I liked the decals, I wanted a more muted effect, more on the fuselage as the wings, so as not to make it too drab/brown.
First, some very careful masking:
Then a custom mixture from Revell Aqua Gloss Varnish (10) with Revell 85 Brown (0,5) and Revell Brick Red/brown 37 (0,5) to make it a bit more reddish, as otherwise it looked kind of off against the red bands right behind it.
The effect on the wings is kind of hard to photograph, so I've included a strip of the original decals for contrast. Like I wrote, I wanted more on the fuselage and less on the wings (found a few pictures like that):
It took me a while to get this done, as I wanted to do this in daylight so as not to overdo it. In the end I may have gone a bit too far on the fuselage, but I can live with it. Despite the brownness I think it looks pretty neat.
I've now masked off some things again to protect it with a further glosscoat, then it's on to some detail painting, some tiny touch-ups (I pulled a few tiny bits off the brown varnish that really show up) and decals -I look forward to that last part as it'll hopefully give it more character. Then it's off to get rid of the new looking red and white to match the toned down lozenge. :)
Jeroen
« Last Edit: October 10, 2018, 05:25:46 AM by jeroen_R90S »
« Reply #102 on: October 10, 2018, 08:36:00 AM »
    WOW! Jeroen, I really like the results. That reddish brown varnish effect is very effective and looks like the real thing to my eyes. Unless I'm confusing my memory of the Knowlton Fokker preserved here in Canada (I've only seen photos not the real thing regrettably) the finish on your fuselage matches it's fabric. I'm definitely going to try this with a D.VII I've got waiting in the assembly line.
    VERY impressive work, this is going to be a spectacular model. 8) 8) 8)
Offline jeroen_R90S
« Reply #103 on: October 14, 2018, 07:00:40 AM »
Thanks Lance! Although I do admit it was kind of a big step without really a way back, I somehow felt I needed to do this, and so far I'm quite happy as well! :) I have, in the meanwhile, coated it all in gloss and am now painting small details. Also gave the propeller it's woodgrain, but it's not dry enough to take reliable pictures.
Hopefully an update later this week!
Jeroen
« Reply #104 on: October 14, 2018, 06:55:15 PM »
Hi Jeroen,
   I really like the effects you've given the lozenge.
Gaz
