Author Topic: Another Wingnut Wings SE5a  (Read 28261 times)
Offline steveb
Re: Another Wingnut Wings SE5a
« Reply #75 on: December 22, 2016, 01:42:26 PM »
Very nice! I love the subtleties of the weathering. Just right!
« Reply #76 on: December 22, 2016, 03:58:19 PM »
Very impressive progress. All Parts look fantastic and I love the way you wrapped the cabane struts. Very clever!
Borsos
« Reply #77 on: December 22, 2016, 05:16:29 PM »
Wow, Tug,
you make this IMHO rather "boring" looking plane becoming a real stunner.
Such an outstanding detail paintjob! Thank you for showing.
Bye,Manni
Offline Suffolk Lad
« Reply #78 on: December 22, 2016, 09:24:26 PM »
Hi 'Guys' - As always, thank you all for your interest and input  :).
I confess I do like weathered subjects   ::) but I know it's not everyone's cup of tea and I guess I do tend to over do things but I'm glad you like it.
Ian - many thanks for describing your method.  I have done similar with flicking paint off a brush onto armour subjects as well but of course the area is far more open than the semi defined area of wheel spray under a wing. It's controlling that area that I found difficult. The Kleer 'spotting' followed by pigment is new one on me though so will certainly try it out. Thanks indeed for the tip. That's some nice shading/highlighting on that DVII BTW particularly on the fuse  :)
Having a good clean up this morning- Ha, been reading Anthony Beevor's book on the Ardennes offensive and have been sidetracked looking into a couple of armour kits  :o
Thanks again,
Regards - Tug
« Reply #79 on: December 23, 2016, 12:32:09 AM »
She's lovely Tug.
for the spattering -- tried a toothbrush? Cut all but one row down flush with the base. Load with paint, flick with thumb by ruffling. Practice on scrap. Works for me!
« Reply #80 on: December 23, 2016, 12:39:57 AM »
Superb work, Tug! She is really coming together now.  ;)
vB
Offline Suffolk Lad
« Reply #81 on: December 23, 2016, 04:42:38 AM »
Thanks Bo - nice one.
Yep I've used a bristle brush in that fashion before but no, never ever crossed my mind to take out all the bristles save a row  ::) Now that is lateral thinking  :D. I will try this out forthwith.
Strange you and Von B think of the aircraft as a 'she' - I thought that was reserved for ships - it's usually an 'it' for myself
Thanks for looking in
regards - Tug
« Reply #82 on: December 23, 2016, 05:46:57 AM »
Wow! Some wonderful weathering and dirt effects there, Tug! Very enjoyable to watch the progress on this!Some great inspiration! Regards, Marc.
Offline Suffolk Lad
« Reply #83 on: December 26, 2016, 06:18:39 AM »
Hello Marc - nice to hear from you  :).
Nope guys, I haven't managed to escape today but I did get this far yesterday. All the parts on now save the struts which just require finish painting before the top wing goes on.
This is always a worrying moment though it always seems to work out okay, A heavy wash of white spirit and a ouch of Lamp Black and Burnt Umber (Alkyd) oil paint has just been applied.
Ten minutes later with the spirit evaporated off a wide flat brush was used to smooth the residue out
I had to have two goes at gluing the cabanes in as two of them didn't take the liquid cement well. Revell Contacta proved a much better bet. Rigging is Ushi Standard line. The rigging on the U/C is mono filament in the hope that this will help strengthen the rather flimsy structure. There's one or two small areas that  require touching up but this week should see it come together.
That's it for today, hope you've had an enjoyable day as I have had, I'm now going to put my feet up with a large malt and watch the box for the rest of the evening
Merry Xmas to you all - Tug
« Reply #84 on: December 26, 2016, 06:53:38 AM »
Great looking bird, Merry Christmas and enjoy your adult refreshment, you've earned it!!!    ;D
« Reply #85 on: December 26, 2016, 09:18:59 AM »
Absolutely stunning results Tug! Your re do on the letters worked great and the washes/filters re terrific.
« Reply #86 on: December 26, 2016, 09:45:45 AM »
This is looking better and better with each update, excellent work Tug and a merry Christmas to you as well.
Offline aliluke
« Reply #87 on: December 26, 2016, 11:27:58 AM »
Looking better all the time...still so much for me to learn!
How does the white spirit wash work? Sounds a bit scary. Does it just add another layer of washing/weathering?
Thanks
Alistair
Offline Suffolk Lad
« Reply #88 on: December 26, 2016, 08:38:16 PM »
Hi Rick, Des and Alistair - my thanks as usual   :)
Alistair - It works by providing a very thin layer of the diluted paint evenly over the surface. Once the thinner has evaporated it leaves residue of the oil usually in any engraved line or accumulating at prominent edges. On Flat Tamiya paint it will also have an effect of staining it slightly which helps even things out - a bit like a glaze on a painting. As you can hopefully see from the first image it is mostly thinner with very little colour. Using it over acrylic, if it does appear slightly overdone, it can be reduced some by a wiping over with clean thinner on a wide flat brush though if it has 'stained' a light colour too deeply this does not have much effect. Despite doing it for many models now I always have reservations just before I apply it but it always seems to come out okay.
The model can be clear coated beforehand which will prevent the staining but then the effect is not the same.
Hope this is of help
Regards - Tug
Offline Suffolk Lad
« Reply #89 on: December 27, 2016, 09:21:11 AM »
Hi Bertl,
Thanks for looking in - your comments are much appreciated  :)
All the small parts remaining are now finish painted and ready to fit so it's just the rigging lines to attach to the top wing and the struts to the lower and it can come together at last. Need to begin thinking about a base now as well.
Back soon - Tug
