Author Topic: Bristol F.2B Fighter (1/32, Wingnut Wings)  (Read 36309 times)
Re: Bristol F.2B Fighter (1/32, Wingnut Wings)
« Reply #30 on: September 25, 2016, 07:13:10 AM »
Thanks, UFAG, Adam, Steve and Mike for you comments.
Mike, it was not at all difficult to pass the control lines through the openings in the fuselage just before closing it. My two hands were more than enough ;)
« Reply #31 on: September 26, 2016, 05:10:43 AM »
Outstanding interior as I said before! Looks terrific all closed up and in place!
Offline xmald
« Reply #32 on: September 26, 2016, 06:26:31 AM »
The interior is absolutely brilliant. I really like the way you reproduce leather - it`s very convincing.
Best regards
Filip
« Reply #33 on: October 09, 2016, 12:44:44 AM »
A brief report from quite long tedious work. Cleaning the parts, removing injector marks from the engine cowlings (I have decided to mount the bottom and side ones and leave the top ones off), drilling the holes for rigging, inserting 110 Bob's eyelets, checking them for pull-off, three sessiong of filling and sanding of fuselage seams. Reinforcing the ailerons, elevators and rudder joints with pieces of wire. Degreasing the surfaces with mild detergent. And finally the elements are ready for airbrushing!!!
« Last Edit: October 12, 2017, 10:06:46 PM by PrzemoL »
Offline xmald
« Reply #34 on: October 09, 2016, 12:48:58 AM »
Great work Przemek - 110 is a hell lot of eyelets. I wouldn`t expect to use that many for the Bristol. Keep up the good work!
Best regards
Filip
« Reply #35 on: October 09, 2016, 12:59:08 AM »
Terrific prep work! 110 is a lot. I guess I will have a lot of holes to drill when I get around to mine  :(
« Reply #36 on: October 09, 2016, 05:50:34 AM »
Excellent work so far Przemol.
« Reply #37 on: October 09, 2016, 05:59:22 AM »
Great work so far, Prze. And good timing too, since I started this kit a few weeks ago. I'm looking forward to following your build and picking up on some tips as I work along with mine, too (along with a DFW late at the same time).
Hopefully I can post a few pics of my builds soon  8)
« Reply #38 on: October 09, 2016, 06:10:54 AM »
Your efforts will be rewarded in the end.  Looking really good.  Look forward to next update.
Offline steveb
« Reply #39 on: October 09, 2016, 07:07:23 AM »
Ah, very nice! Yes, a LOT of eyelets!
« Reply #40 on: October 09, 2016, 07:43:03 AM »
Thanks, gentlemen for your kind comments.
Gary, I am looking forward to see your builds. I may be able to see what I have done wrong in mine :)
Honestly,  I was also surprised to count 110 eyelets. But then, if you think of double flyings wires, two bay wing cellule, it suddenly becomes evident.
Offline jeroen_R90S
« Reply #41 on: October 10, 2016, 04:17:50 AM »
Exactly that amount of eyelets and rigging has kept me away from saving up for a Bristol... (saving for a Snipe now) You make it look easy -when I try to make close ups of my work there are always glue fingers, damages and other mischiefs showing up. :)
« Reply #42 on: October 10, 2016, 09:37:56 AM »
great thus far , cheers
« Reply #43 on: October 10, 2016, 03:43:51 PM »
Thanks.
Jeroen, sorry to say this, Snipe with basically the same wings arrangement as Bristol will have the same number of eyelets necessary. And it will be more cramped due to smaller dimensions... If you wish to escape rigging, go for German designs.
« Reply #44 on: October 10, 2016, 11:01:41 PM »
Thanks.
One difference. The Snipe doesn't have any Double wires  ;D
