Under Construction
Bristol F.2B Fighter (1/32, Wingnut Wings)
Pages:
3
4
11
Topic: Bristol F.2B Fighter (1/32, Wingnut Wings) (Read 36456 times)
PrzemoL
Re: Bristol F.2B Fighter (1/32, Wingnut Wings)
Reply #15 on:
September 19, 2016, 05:23:44 AM »
Thank you, everyone, for cheering! It is great to have so many faithful fans
Jacek, luckily the wooden pieces were "cut" by WNW themselves
Borsos, the wicker seat is indeed from the box but modified as per WNW website - that thick piece of plastic at the outside of the seat where there should be perforation was removed. It worked quite fine at the back, were it was vital as this part will be visible from the gunner cockpit. The sides were not so easy and I managed to break some of the strings when scraping the exterior but the sides will not be visible from outside, and on the inside some wash masked the mess.
Well, I understand those who consider this kit as WNW best. I cannot be sure if it is truly the best in their entire production line but it does assemble easily and without problems. The interior is now completed, with the exception for the seat belts. I have added the rigging (remembering the nightmare I invented with Snipe I have done this prior to the assembly) and control lines and besides this - two throttle linkages from black wire. The rest is from the box.
And testing how it will be with the fuselage interior painted CDL and aluminium.
Last Edit: October 12, 2017, 10:04:22 PM by PrzemoL
Reply #16 on:
September 19, 2016, 07:41:15 AM »
Your interior looks even better all put together, if that is possible !
lcarroll
Reply #17 on:
September 19, 2016, 11:04:31 AM »
Spectacular work Prze, The clean finish and super detail of the cockpit are most impressive. I'm one of the great "fans" of this kit as being the best of WNW's releases, and you are certainly solidifying that impression! At this rate I may have to try to get another into my Stash!
bobs_buckles
Freedom isn't free.
Reply #18 on:
September 19, 2016, 04:48:58 PM »
Great work, Prze!
vB
Des
Reply #19 on:
September 19, 2016, 07:01:11 PM »
Looking absolutely brilliant Przemol, the interior is superb.
Des
Ernie
"Once more into the breach"
Reply #20 on:
September 20, 2016, 03:26:26 AM »
Quote from: Des on September 19, 2016, 07:01:11 PM
Des
I couldn't agree more! A real pleasure to watch the magic, my friend!
Ernie
Reply #21 on:
September 20, 2016, 05:23:37 PM »
Ah, yes, this looks stunning, you did a geat job on the interieur.
Thanks for showing.
coyotemagic
Reply #22 on:
September 21, 2016, 12:39:43 AM »
Gorgeous, gorgeous, gorgeous interior, Przemo!
lone modeller
Reply #23 on:
September 21, 2016, 04:10:29 AM »
What can I add which has not already been written? Clearly a good kit buyt then the modeller is adding something which makes it better than good …..exceptional!
Monty
Reply #24 on:
September 21, 2016, 05:01:43 AM »
All I can say is it looks absolutely wonderful! I see what you mean about adding the control lines at this stage... I will follow and enjoy! Marc
PrzemoL
Reply #25 on:
September 23, 2016, 06:53:22 AM »
Thank you, everybody, I am very glad you like my work on the Biff. So here is more: the seatbelts were added, the fuselage is closed, joints filled, sanded and polished. Still, I have to apply some primer to check the quality of this work to call it done. In short, I am now entering the phase of little mediatic, tedious but vital work on cleaning the joints, preparing the main assembly bits for the paint. It will take some time... And yes, there are many holes to be drilled for rigging.
Last Edit: October 12, 2017, 10:05:27 PM by PrzemoL
UFAG
Reply #26 on:
September 23, 2016, 07:05:33 AM »
Stunning...!!Very fine finess.
Adam
Reply #27 on:
September 23, 2016, 09:38:34 PM »
Przemol nice to see your new production.
Recently, I have a lot of work, I am a guest in the house, and only now I noticed your topic.
As usual with curiosity I'll be here looking in.
Adam.
mike in calif
Full Member
Reply #28 on:
September 24, 2016, 12:28:44 AM »
Very nice! How many hands did it take to run the wires through the fuselage, while closing it up and getting it all aligned?
steveb
Full Member
Reply #29 on:
September 25, 2016, 03:05:26 AM »
Love that interior!
Pages:
3
4
11
Under Construction
