Author Topic: 1/72 Eduard Albatros D.V. My first WWI build since 1968...  (Read 24365 times)
Offline Cajun
Re: 1/72 Eduard Albatros D.V. My first WWI build since 1968...
« Reply #45 on: September 19, 2016, 07:57:26 PM »
Loving it!
Online PrzemoL
« Reply #46 on: September 20, 2016, 05:24:40 PM »
Fantastic woodwork. But it just matches the great detailing inside the fuselage. The masterpiece in the making.
Offline UFAG
« Reply #47 on: September 22, 2016, 09:21:51 AM »
Very well done...and in 1/72...!!
Online IanB
« Reply #48 on: September 22, 2016, 10:41:58 AM »
This would be outstanding in 1:32, in 1:72 it's simply astonishing!
« Reply #49 on: September 23, 2016, 12:16:52 AM »
Looks like 1/32 if I did not know any better, great skills.  This is art!!!
Offline Edo
« Reply #50 on: September 23, 2016, 12:45:02 AM »
I cannot say nothing more than Jouan has already said!
Truly amazing!
ciao
Edo
Offline steveb
« Reply #51 on: September 23, 2016, 03:51:15 AM »
I'm a bit late to respond, wow, thanks so much!! Once again, I have learned so much from those of you who post here. I still continually go through many older posts to see how certain tasks are handled, especially in 1/72.
No photo update, but I have since sprayed quite a few coats of clear on the fuselage in preparation for decals. Masking was removed, & I only had a minor bit of water color that seeped under the masking on the nose. Easy cleanup, though.
More clear was also added to the top wing for decal prep. I glued the PE piece for the aileron control horn to a small piece of foil to represent the base of the cover. I was curious if I should glue it to the wing, then apply the decal (with a small slit cut into it)? Or, should I glue the control arm on after the decal has been applied?
Thanks again,
Online IanB
« Reply #52 on: September 23, 2016, 09:33:23 AM »
Really?? I'd never even noticed that little plate before! Personally, I'd put the decal on first and then paint the control horn cover to match...
Offline steveb
« Reply #53 on: September 23, 2016, 12:12:04 PM »
Thanks, Ian, I appreciate the input! I painted them shortly after I made them.
As it stands today. Much more to do.
Offline TobyCoulson
« Reply #54 on: September 23, 2016, 04:23:15 PM »
Every time I visit this thread I am stunned by the standard of modelling.
Offline Cajun
« Reply #55 on: September 23, 2016, 10:46:27 PM »
Once again Steve..... Very very nice!
Offline Dirigible-Al
« Reply #56 on: September 24, 2016, 06:27:40 PM »
I stuck those control horns on an Albatros I made a while ago but the crazy thing is it was in 1/48 and they are less detailed than your 1/72 ones.
Amazing.
« Reply #57 on: September 25, 2016, 02:44:14 AM »
Incredible detail on those control horns!
Offline Jorgo
« Reply #58 on: September 25, 2016, 05:03:57 AM »
Wonderful modeling in every aspect!
Chapeau!!!
Highest regards
Jörg
« Reply #59 on: September 26, 2016, 05:12:19 AM »
Chapeau!!!
Highest regards
Jörg
I think this says it all !
