Author Topic: CSM Salmsom-Moineau S.M.1 1:48 scale  (Read 71112 times)
Offline boggie
Re: CSM Salmsom-Moineau S.M.1 1:48 scale
« Reply #120 on: July 12, 2016, 08:29:11 PM »
Great paint job and attention to detail Des.
To say it's looking good is definately an understatement, but
it is LOOKING REALLY GOOD!
More please.   :)
« Reply #121 on: July 12, 2016, 09:20:42 PM »
Thank you Boggie for your very kind comments, they are much appreciated.
Offline stefanbuss
« Reply #122 on: July 12, 2016, 09:38:00 PM »
Des,
are you going to tone down (flatten?) the gloss a bit, or is going to stay so shiny?
S.
« Reply #123 on: July 12, 2016, 09:42:15 PM »
The gloss coat was applied so I could add the decals, I will be giving the whole model a few coats of satin clear once the other propeller mount is fitted.
Offline markleecarter
« Reply #124 on: July 12, 2016, 10:51:38 PM »
Just beautiful!
« Reply #125 on: July 13, 2016, 12:48:15 AM »
Just superb  :)
vB
« Reply #126 on: July 13, 2016, 07:45:26 AM »
Brilliant painting, decal work, and detailing!
« Reply #127 on: July 13, 2016, 11:18:28 AM »
Rick sums it up and I couldn't agree more!
Beautiful job, Des. :D
« Reply #128 on: July 13, 2016, 01:14:11 PM »
Thanks guys for stopping by and leaving your much appreciated comments.
When fitting the struts I cut off the resin pins and replace them with 0.5mm copper wire, I drill a 0.6mm hole into the end of the struts then CA the copper wire, the wire can then be cut and bent to shape, it is very easy to work with but makes a strong connection.
I finished the two propeller drive gearbox units and fitted them to the bottom wing, the main drive from the engine to the two gearbox units are also fitted. I was very surprised at how easy it was to fit these units, finding the correct length strut is crucial but having scale plans to compare each strut makes life very easy. Once the correct struts were found both units virtually fell together
« Reply #129 on: July 13, 2016, 02:08:05 PM »
You're really moving right along on this one, Des!  I'm blown away by how quickly and beautifully she's coming together!  Just Lovely!
« Reply #130 on: July 13, 2016, 02:15:41 PM »
Thanks Bud for your kind words. For a limited edition resin kit it is going together really well, I have had a few issues but only minor ones, the lack of instructions are my main concern.
« Reply #131 on: July 13, 2016, 09:41:28 PM »
And even more struts. I have fitted the struts from the propeller mounts to take the top wing, I made a small jig that fitted across the pins on each pair of struts just to make sure everything was aligned, and this isn't the end, there are still more struts to be fitted.
Offline xmald
« Reply #132 on: July 14, 2016, 06:01:05 AM »
Wow what a splendid build Des! Everything looks so easy when you do it... Of only I had a talent like you do...
I think Edgar has made the right decission when he asked you to build this kit. It really makes me want to buy one too.
Best regards
Filip
« Reply #133 on: July 14, 2016, 07:50:39 AM »
Thank you Filip for your kind comments.
« Reply #134 on: July 14, 2016, 10:48:39 AM »
very nice and fast progress,i think you are enjoying this 1/48 kit more than you thought you would.remember there are many many more kits of much more obscure subjects in 1/48.some require some tlc but to me all the more fun. i know you like the be2c roden has a very decent kit of the be2c which can be converted to other be2 models. you can get one for $20 to $25 us dollars. i think you would like many of the cheaper yet still very nice 1/48 kits
