Author Topic: 1:32 Scale WNW Pfalz D.XII #2695/18  (Read 44317 times)
Re: 1:32 Scale WNW Pfalz D.XII #2695/18
« Reply #30 on: May 15, 2016, 08:38:25 PM »
Wow!  Lance my friend, the interior is an absolute gem!  Your attention
to detail is terrific and always takes your models to the next level.  I
am looking forward to the next updates.
« Reply #31 on: May 15, 2016, 08:57:21 PM »
Don't hold back, Lance! You go for it!!  ;D
Coming along nicely  :)
vB
« Reply #32 on: May 15, 2016, 10:34:14 PM »
    Thanks for your comments and encouragement, Guys. The pace will slow a bit now as warmer weather makes Spring clean up of the yard less avoidable; a rake or shovel are more likely in my immediate future then a hobby knife this fine day! :(
Offline BigBlue
« Reply #33 on: May 15, 2016, 11:00:46 PM »
Really nice start, Lance!
« Reply #34 on: May 15, 2016, 11:42:15 PM »
Great start on the cockpit, Lance. The scribing on the fuselage wall is a nice thing to note. I'll have to wait until my second build on this since mine's buttoned up now!
And I probably won't buy a second one until Richard releases a custom set of lozenge decals for this thing - the rib-taping is going to take forever!
« Reply #35 on: May 16, 2016, 12:00:03 AM »
   Thanks Chris.
   I'll admit that I find rib taping just slightly less thrilling then a root canal as well, Gary. On the other hand I find the "cookie cutter" type of decals harder to work with then the "handraulic" approach with strips and tapes, more margin for error with the latter method. I do have Richard's Roland D.VI custom set and will use it when I get to that Build, perhaps practice will make more perfect!
Offline stefanbuss
« Reply #36 on: May 16, 2016, 04:11:56 AM »
Lance,
I would like to learn more about those veneer strips. What width did you use (do you have any measurements within your documentation?)?
Stefan
« Reply #37 on: May 16, 2016, 05:11:53 AM »
Lance,
Stefan
Stefan,
    I used a thin piece of evergreen Sheet Styrene as a straight edge guide for the RB Productions Scriber shown in the original photo. The spacing was based on a photo of Frank Talman's 7511/18 in Windsock Worldwide Vol.27 No. 5 of Sept. Oct. 2011 in Ray Rimell's Build article. I used 4.5mm spacing based on the comparison to the Bosch Magneto in the photo. Out of curiosity I just measured the width of the strips on the D.IIIa Kit in my Stash, it's less then 3mm.
If you don't have the Windsock issue there's a photo of the fuselage behind the seat of the Australian survivor, 2600/18 on page 4 of the Plans Booklet that shows the untouched original finish, and the wider strips.
   There is another very good photo in Datafile 41, pg. 28, upper left which shows the cockpit of 2600/18 with the wide strips however they are vertical as opposed to diagonal......?? The production line photos from the Factory show a diagonal lamination of the fuselage shell, maybe the angles differed from one airframe to the next?
 Hope this helps.
« Reply #38 on: May 16, 2016, 09:24:55 PM »
Good information Lance and thanks Stefan for asking!
« Reply #39 on: May 17, 2016, 07:30:34 AM »
Hi Lance
Logo in the post!
I have included basic instructions for transferring the vinyl logo from it's backing paper to your desired surface. Enjoy!
vB   ;)
« Reply #40 on: May 17, 2016, 11:41:40 AM »
Thank You von Logo Meister, I'll advise when it arrives in the "Cool Pool"!!
Offline jknaus
« Reply #41 on: May 17, 2016, 11:59:09 AM »
Its not that cold Mr Von Buckles. The ice has sunk down a good few inches and there is open water to be seen lol.
James
« Reply #42 on: May 17, 2016, 12:12:40 PM »
James
   Good points James; we did have Summer today, I actually had an ale on the deck in my shirt sleeves! I'm hoping to see a Humming Bird or two before the Fall, next week!  :-\Actually, if we don't get some rain real soon we may be moving south anyway, just ahead of the wild fires!
Offline stefanbuss
« Reply #43 on: May 17, 2016, 02:25:24 PM »
Quote
That's way too much distraction. Back to the modelling bench, Sir!
« Reply #44 on: May 17, 2016, 11:25:28 PM »
    It's not as bad as it sounds Stefan; I had the Datafiles with me! ;) :)
