Author Topic: 1:32 Scale WNW Pfalz D.XII #2695/18  (Read 44318 times)
Re: 1:32 Scale WNW Pfalz D.XII #2695/18
« Reply #15 on: May 13, 2016, 10:49:52 PM »
Hey Lance - great choice! Finished your yardwork already? 8) I'm actually halfway through my build of the same kit - using Aviattic's lozenge for the wings. I'll have to slow down my progress and take advantage of the clinic you'll be no-doubt putting on  ;)
Cheers!
« Last Edit: May 13, 2016, 11:04:59 PM by gedmundson »
« Reply #16 on: May 14, 2016, 12:22:44 AM »
   Stefan, Sasho, thanks for checking in, I'll look forward to your suggestions and feedback.
   von Pfalzfan, many thanks, who wouldn't want a custom made Pfalz Logo, in black of course!
   Tug, Rick, the bench looked too "staged"  all cleaned up, Better Homes and Gardens it ain't no more with another Build spilling over the edges!
   Manfred & Ernie, thanks for your encouragement. (Ernie, the colour Scheme is at the beginning of this Log.)
   Richard, many thanks for the kind offer but I actually prefer the Full Pattern Width version of your Lozenge, I end up cutting chord wise every bolt line anyway to keep the pieces manageable.
Gary, great minds apparently think alike. I think me catching up with your progress (and quality) would be more likely, your Builds have so much to inspire us here! What scheme have you decided on?
« Reply #17 on: May 14, 2016, 12:30:15 AM »
Black it is then, Sir!
Pale white hand by mouth of postbox coming to an email address near you.... SOON!
vB    ;)
« Reply #18 on: May 14, 2016, 12:40:08 AM »
Gary,
     The cold weather has provided the perfect excuse to delay such drudgery; some time in the references and scraping plastic is a reasonable substitute! ;) You??
Offline jknaus
« Reply #19 on: May 14, 2016, 01:47:51 AM »
Oh yeah, this should be fun to watch Lance. Will pull up a chair and some popcorn and have a watchsee :)
James
« Reply #20 on: May 14, 2016, 01:53:47 AM »
Great subject, you'll make another beauty out of it. I'll follow your built closely (the toko Pfalz D XII was one of my first WWI kits ever about 15 years ago... I always loved this airplane)!
Borsos
« Reply #21 on: May 14, 2016, 01:59:20 AM »
Let the games begin!!!
« Reply #22 on: May 14, 2016, 05:13:57 AM »
Gary,
Hi Lance - I've chosen the "A" scheme from the kit with the older style tail and the swastika. Gives me a chance to do that weathered silver-grey scheme which will be the challenge.  And as far as yard work - it was so warm last week when we returned from holidays we got our grass done and Marianne has made good progress on the winter-cleanup (she's the gardener!) so I'm good to keep going on the DXII and DIIIa (which I should have done for the Edmonton show!).
« Reply #23 on: May 14, 2016, 09:59:28 AM »
James, Borsos, and Steve,
   Thanks for the encouragement, I'm looking forward to getting this Build moving along, I'm really "futzing" with the cockpit for some reason, probably due to conflicting references as the main sources are restorations, all slightly different in layout.
Gary,
    Your scheme is a reason I'd consider a second Kit, I really like the old style tail and the silver and blue is a very attractive scheme. I'll look forward to seeing both in two weeks..........what scheme for the D.IIIa?
« Reply #24 on: May 14, 2016, 01:17:42 PM »
Gary,
The DIIIa will be the wartime version of the "old workhorse" that Bertl "Umlaufmotor" did with the black fuselage and the diagonal stripes on the tail (#23 painted on it during post-war training). I begged him to tell me how he got the weathered look to the black scheme, and as much as he shared I couldn't match it - but I'm somewhat pleased as to how it's coming along.
The DXII won't be done by the end of the month, unfortunately but I'll bring along my progressed build for you to see.
« Reply #25 on: May 14, 2016, 10:14:24 PM »
   "I'll bring along my progressed build for you to see."
    Looking forward to it!
« Reply #26 on: May 15, 2016, 12:29:04 PM »
    Well, the first step is more or less complete; the cockpit module is completed and now the engine can be tackled. There's still a bit to go on this step, most important the seat belts need to be added.
     I elected to go with the "Grey-Blue" interior colour as opposed to the "Grey Green" as the references stated a good case for the former, based on the initial assessment of the Australian war Memorial's 2600/18. I started by scribing the veneered strips on the interior walls of the fuselage, a detail WNW included in their excellent Pfalz D.IIIa Kit but not this one.
   The rigging lines were added using EZ Line after drilling the flight control components.
    The seat was done with a mix of Tamiya browns to achieve a reddish brown and then "washed" with a thinned Winsor Newton "Lamp Black" mixture. The compass and fuel gauge are kit decals, Aeroclub Bezels, and Future was used for lenses.
   The "horse shoe Brackets, levers on the bulk head, and the brass selectors for the fuel control panels were done with scrap Photo Etch enhanced with a coat of Medium CA. Unfortunately a lot of this detail will be "buried" when the fuselage is closed up.
   The Machro Mode has shown here that a bit of touch up is needed on the control column grips, and the spot on the seat can be covered by the belts when installed. The three cables from the control column will be added when the fuel tank and magazine are installed later. The instrument below the fuel pressurization hand pump was an add-on as well, scratch built.
   The Spark Advance/Retard Lever is "free -floating here, it needs to be attached to the fuselage wall when the module is permanently installed.
   The tiny Fuel Control Panel was a "B*&*&H" to fit in. a genuine three handed affair!
   Last, the module, with the Firewall dry fitted was tested in the left fuselage half, and appears to be a good clean fit.
    So, now it's on to the engine; I'll only be detailing the top end on this one as the model will be completely "cowled" when complete. :)
« Last Edit: May 15, 2016, 12:37:36 PM by lcarroll »
Online RAGIII
« Reply #27 on: May 15, 2016, 02:12:17 PM »
Beautiful interior Lance! You are moving right along on this one!
« Reply #28 on: May 15, 2016, 03:31:55 PM »
Superb work on the interior details Lance, you have an excellent eye for detail and your certainly know how to pick the correct colours, looking forward to the next update.
Offline Russell
« Reply #29 on: May 15, 2016, 06:43:23 PM »
All the tricky work on the interior will pay dividends when you peer into it on the finished build a catch a glimpse of the control wires etc. Well done.
Russell
