Author Topic: 1/72 Airfix Albatros D.Va Ernst Udet  (Read 4215 times)
Offline Bolman
« on: April 26, 2016, 12:18:38 PM »
Hello all,
I started this one on the 10th of this month not intending to actually build it, but just to test applying the lozenge decals I came across in my stash. I found I had a complete set of upper and lower decals from Pegasus.
After spraying a sealer on them lightly, I went to work. Mind you, I have built over 60 planes and never done any of them with lozenge decals before, so this was new to me. Also new to me, is using Future. I used it quite extensively on this build with all the layers of decals involved.
For now, I only have a few pictures since I'm pressed for time getting ready for a convention this weekend.
I started with one of those kits in my stash that I managed to acquire when someone gave me a group of kits as trade for building a plane for use as a game piece. This particular kit was missing the engine and the tail plane and had one of the prop blades broke off of the spinner and one of the landing gear struts was missing part of one strut.  I scrounged through my box of spare parts and found all I needed to make the plane whole except the landing gear parts. I had to scratch those.
The crosses are all from extra decal sheets and the LO is dry transfer lettering. The marking on the nose is hand painted, but I found a profile picture on the internet and scaled it down to 1/72 scale and printed it. Trimmed out the marking and used it as a stencil to ensure the correct angle and size as I dry brushed through the stencil to mark it on the plane. Once that was done, I hand painted over the marking.
Rigging is all 2 lb test fishing line 0.004" in diameter. The tail plane is hand painted. The axle is from a straight pin with the head and point snipped off.  Paints are Floquil and Testors enamels and Future clear coating.
Thanks for looking!
John
« Last Edit: May 17, 2016, 09:53:38 PM by Bolman »
Re: 1/72 Airfix Albatros D.Va Ernst Udet
« Reply #1 on: April 26, 2016, 12:21:24 PM »
The pics aren't posting John. I've seen this a lot recently with PB, not sure what they're playing at....
Offline Bolman
« Reply #2 on: April 26, 2016, 02:55:11 PM »
All fixed
« Reply #3 on: April 26, 2016, 03:24:01 PM »
She's a beauty, John!  Very well done!
Offline TobyCoulson
« Reply #4 on: April 26, 2016, 05:02:20 PM »
That's a very nice build considering it's a bitza. Highlights your skills very well :)
Offline dtomko
« Reply #5 on: April 27, 2016, 12:29:49 AM »
Very nicely done!
Drew
« Reply #6 on: April 27, 2016, 01:20:06 AM »
That looks great. I wish I could find Future...or Pledge multi-surface finish as it is now. Not one of the local stores has it!
« Reply #7 on: April 27, 2016, 07:09:49 AM »
A very attractive looking model John, you have done a brilliant job with the build and finishing, well done.
« Reply #8 on: April 27, 2016, 08:52:50 AM »
Des said it for me.  Beautiful work John, on a really classy looking model, my friend
« Reply #9 on: April 27, 2016, 10:59:09 PM »
One of the nicest builds of that OLD Airfix kit I can remember having seen! Lovely aircraft!
« Reply #10 on: April 28, 2016, 12:13:11 AM »
John,
    I recall doing this kit in 1965 (bear with me, that was just over 50 years ago!!) in black, Goring's colours, and it didn't look as good as this! Nicely done on a very old and challenging subject.
Offline Bolman
« Reply #11 on: May 02, 2016, 01:28:06 PM »
Thank you all for your kind remarks. I probably could have have spent a lot more time on it making sure it was more detailed and more accurate. It serves it's purpose though and everyone at the convention liked it.
Lance: I've built this kit once before for someone else as the MVR with the red tail and factory camo on the wings and wood fuselage. As I recall, there were fit issues with the method of mounting the prop assembly and the landing gear struts. Taking that experience into account, I totally changed how the prop assembly was done for this one making a conical insert which was drilled for a straight pin for the prop shaft which I mounted the prop/spinner assembly on after making sure there was barely a gap between the two and shaped the broad end of the conical insert to match up with the front of the fuselage and the spinner. In this case, it worked well and looks a lot better than my first go at it.  I used the Jasta 37 scheme since I felt it was the easiest for me to do in the shortest amount of time.
Thanks again everyone!
John
« Reply #12 on: May 03, 2016, 03:25:21 AM »
I built one of these a while ago - it really is an old kit with several fit issues. I too had to build the engine as it was missing in my kit, and as you write the u/c is best replaced. You have made a superb model from this - the markings are different but no less interesting for that and have been really well done, especially the hand painting. I must have a go with lozenge transfers one day too……
« Reply #13 on: May 03, 2016, 06:50:02 PM »
Goodness me, John, that's some fine work on your part. Well done!
Offline Bolman
« Reply #14 on: May 03, 2016, 11:37:56 PM »
Thanks Stephen and Nigel, Much appreciated.
@Ian: I did a quick search for you and Amazon carries what we call 'Future' in it's new packaging:
I still have my original bottle from back in my model railroading days. I had read that there was a scare that it was going to be changed or eliminated back then and bought a bottle, but never used it until now.
There is also this link which may be helpful to you regarding the product: http://www.swannysmodels.com/TheCompleteFuture.html
@Stephen: This plane represents the most I have ever done in decal work. I usually just paint everything if I can get away with it. Looking forward to your attempt!
John
« Last Edit: May 03, 2016, 11:43:13 PM by Bolman »
