Under Construction
Yet another DH.9a (this time from Germany)
Topic: Yet another DH.9a (this time from Germany) (Read 4237 times)
chowhound
Full Member
March 22, 2016, 02:44:48 AM »
Hello friends,
I think it's time for my first building report. As you know, I ordered the DH.9a. After only five days, she was lying on my table! After the usual preparations, I have the frame for the cockpit in light wood Brown painted and provided with a wood grain. Here are the first images.
(The upper frame has no grain. Is unfortunately hard to see, sorry.)
Now I'm waiting for the PE parts of HGW, so I can go on.
Jürgen
Every artist was first an amateur.
Ralph Waldo Emerson (1803-1882)
Oeli
Full Member
Re: Yet another DH.9a (this time from Germany)
March 22, 2016, 03:50:23 AM »
Hi Jürgen,
that makes me happy that it now starts with you with the Ninak.
HGW is pretty fast, because you should not have to wait very long.
I'm curious how it then goes on.
Jörg
Des
March 22, 2016, 06:56:42 AM »
You have made a great start Jürgen, looking forward to the next updates.
chowhound
Full Member
March 23, 2016, 05:50:02 PM »
While I wait for the parts of HGW, I have done my time thinking about the rigging. Although offered EZ-Line products are pretty, but still not to my taste perfectly. Since I made earlier historic ship, I thought, why not make the ropes himself. Here is the result. Links to the images you see a line stretched as it sells EZ, next to the handmade ropes in different strengths. The RAF typical flat cables are possible, as can be seen on the far right.
To be continued
chowhound
Full Member
April 02, 2016, 10:53:39 PM »
Finally it goes on!
After a little forced break (too much work) I have finally managed to continue building a little.
Let's start with the cockpit. First, I have decided the pedals and two joysticks.
What would be a cockpit without flight instruments? Since me the supplied instrument panel not really liked, but this is a matter of taste, it was etched parts of HGW a little refined. (Unfortunately, the record in the "size" with Macro is not so easy, but I hope it goes anyway)
Next construction is the engine. Again WNW provides excellent details that I will improve with etched parts of HGW. So the engine looks at the moment.
That reminds me, the air inlets were a little too thick walls, they have been gently sanded down to a manageable level.
So, that's it for the moment again.
lcarroll
April 03, 2016, 01:43:55 AM »
Great start Jurgen, I really like the planking on the floor board section.
Reply #6 on:
April 03, 2016, 03:26:20 AM »
Looking good! Nicely done instrument panel.
BigBlue
Reply #7 on:
April 03, 2016, 07:01:26 AM »
Nice start Jürgen!
Des
Reply #8 on:
April 03, 2016, 07:04:26 AM »
Very nice work on the instrument panel and the engine.
coyotemagic
Reply #9 on:
April 03, 2016, 08:01:03 AM »
You're off to a great start, Jürgen! I like what you did with the IP.
Ernie
"Once more into the breach"
Reply #10 on:
April 03, 2016, 07:01:56 PM »
Great beginnings, Jürgen. Nice job of the engine and I like
your woodgrain on the floorboards. I look forward to the
next updates, my friend.
Ernie
chowhound
Full Member
Reply #11 on:
April 06, 2016, 04:38:51 PM »
Thanks for the positive feedback!
And on it goes with the interior decoration.
Let's start with the camera to the Enlightenment. Although later barely visible, WNW has provided for the camera lens.
Also on the engine itself has done, even if it is only the suspension. This I have only painted black, and have then applied with a bristle brush Wood Brown to get a dirty wooden surface.
It continues with the various lifting and control cables and control rods.
The levers of plastic I have replaced with etched parts of the HWG. The first self-made ropes now been used.
And brought to completion the grid structure with additional parts, as well as the engine, the view into the fuselage shell.
I guess the effort with the control cables, and the tension wire was worth it.
To be continued
mike in calif
Guest
Reply #12 on:
April 10, 2016, 12:51:08 AM »
Coming along nicely! How are you going to do the "ears' that stick out of the fuselage for the rudder cables?
chowhound
Full Member
Reply #13 on:
April 11, 2016, 10:19:57 PM »
Today I want you to show the almost-finished inner section. It now missing only a few connections to the engine and the battery. The engine is preliminary but placed only in the holder. Also in this assembly the fit is excellent. A little tip on the edge, for those who have never had a Wingnutkit in his hands. Unlike most manufacturers, make sure the stick, which is at the splices
not [/ B] color. Not only, that would not keep the adhesive as well, even the splices or connection points almost "suction" designed. Any paint prevents the mating of the parts! As usual, still images at the current stage.
To be continued
Reply #14 on:
April 11, 2016, 10:57:48 PM »
You re making great progress on this one. Looking Terrific!
Under Construction
