Author Topic: Jeannin Taube - 1:32 scale  (Read 75549 times)
Re: Jeannin Taube - 1:32 scale
« Reply #120 on: October 11, 2012, 12:40:45 PM »
That's the easy bit done... ;)
« Reply #121 on: October 11, 2012, 01:16:53 PM »
This project scared me at the start but now that I have settled in I am enjoying every aspect of the build.
Des, I have the Copper State and the Flashback 1/48 scale Taubes and was a bit scared to start them, as well.  Watching this amazing project progress has taken away all (well, most) trepidation.  Thank you so much for blazing the trail so brilliantly.
« Reply #122 on: October 12, 2012, 10:59:00 AM »
The tail end rigging is now completed, not as hard as I first thought it would be. The biggest issues were the eight lines running to the elevator, as each line was tensioned the two either side slackened, so it was a matter of continuing to tension until all lines were equally taut, time consuming but not difficult. As can be seen, there is a turnbuckle on each line, the small triangle where all the cables join was made from two pieces of thin brass sheet, the lines were sandwiched between the two plates and super glued.
« Reply #123 on: October 12, 2012, 11:30:26 AM »
She's a beaut!!!
« Reply #124 on: October 12, 2012, 11:43:05 AM »
Gorgeous rigging, Des!
Offline Whiteknuckles
« Reply #125 on: October 12, 2012, 02:48:04 PM »
Now that looks fiddly in the extreme but so very much worth it. Excellent Des ;)
Eternal Apprentice
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
« Reply #126 on: October 12, 2012, 04:13:13 PM »
Hi Des
The Jeannin Stahltaube is the perfect canvas for your superlative rigging. Wahoo! Really gets the viewers attention.
Eye candy indeed
James
Happy Modelling
James Fahey
Offline Ian from Doncaster
« Reply #127 on: October 12, 2012, 04:43:14 PM »
Superb Des... Excellent build all round.  Looking forward to the wings.!!!
« Reply #128 on: October 13, 2012, 01:04:00 AM »
Truly lovely, Des!
« Reply #129 on: October 13, 2012, 01:51:29 AM »
Simply awesome Des. Your rigging looks immaculate as always. The profile view is the one that caused my jaw to drop as it gives me a glimpse of how difficult it must have been to get everything squared up and properly tensioned. A mere mortal like me would never even consider attempting anything so demanding. I tip my hat to you . . . again!  ;D
modelmaker
« Reply #130 on: October 13, 2012, 09:58:51 AM »
Des your passion and dedication for your hobby really shows in your work there would only be a handful of people on this planet who can achieve this level of detail at this scale and all from scratch, amazing work, what more can be said!
Sean
Offline drdave
« Reply #131 on: October 13, 2012, 06:25:09 PM »
I verify your goodness, Des ;D
« Reply #132 on: October 14, 2012, 08:14:47 AM »
I'll never "quack" again about how tough a rigging session was; simply incredibly magnificent work Des, what a beauty indeed!
« Reply #133 on: October 14, 2012, 10:41:00 AM »
Thank you very much for all the lovely comments, they are much appreciated.
I have a small update. I made the first radiator which I have already mounted on the left side of the fuselage, I used 0.4mm brass coated copper wire for the radiator core, this was purchased from a craft/beading shop. I will spend today making the other radiator.
« Reply #134 on: October 14, 2012, 11:31:16 AM »
Brilliant!
