Author Topic: 1/48 Eduard Albatros DV  (Read 21723 times)
Offline TobyCoulson
Re: 1/48 Eduard Albatros DV
« Reply #60 on: February 05, 2016, 09:41:11 PM »
Slow progress this week as I've been out and about. The Aviattic lozenge decals are superb to work with if a little confusing on the eye but I guess that's the purpose of them ;D
« Reply #61 on: February 06, 2016, 02:21:07 AM »
Beautiful work, Toby!
Offline TobyCoulson
« Reply #62 on: February 06, 2016, 05:09:13 PM »
Thanks Bud. I now have the exciting job off putting on rib tapes. I got some from Old Propeller that are the right scale but look odd on top of the lozenge
« Reply #63 on: February 06, 2016, 09:11:27 PM »
Toby,
I agree with Bud, Beautiful Work!
Offline TobyCoulson
« Reply #64 on: February 06, 2016, 11:40:19 PM »
Ribbing now on. That was a interesting character building episode. Still I  learnt a lot for the next time I do it.
I assume ribbing is on the underside as well?
« Reply #65 on: February 07, 2016, 12:19:47 AM »
Your tapes look great! You seemed to have done well on your learning curve!
« Reply #66 on: February 07, 2016, 12:48:47 AM »
Very nicely done so far  8)
Offline dtomko
« Reply #67 on: February 07, 2016, 03:14:29 AM »
I agree; the rib tapes look great!
Drew
« Reply #68 on: February 07, 2016, 04:30:44 AM »
Good work.
Offline TobyCoulson
« Reply #69 on: February 08, 2016, 12:03:44 AM »
Doing the underside of the top wing and I think it's best to do it in segments to aid cutting and positioning.
The wrinkled look is because I just put them on whilst the other side has dried and been trimmed.
Offline jeroen_R90S
« Reply #70 on: February 08, 2016, 06:52:41 AM »
Probably a wise move to do it in bits. I did do the part around the radiator from a single bolt by using a piece of masking tape as a template.
Miraculously it fitted quite well after only 2 tries!
Looks good, I really love the colours of the Aviattic Lozenge :)
« Reply #71 on: February 08, 2016, 07:04:10 AM »
You are doing a superb job with this model Toby and the lozenge decals look great, well done.
Offline jeroen_R90S
« Reply #72 on: February 08, 2016, 07:11:31 AM »
Now that I'm looking again, is it applied spanwise on the upper wing bottom? I did my 1/72 version in up-and-down bolts. I must admit I'm probably a bit cross-eyed after doing mine, however!
Offline TobyCoulson
« Reply #73 on: February 08, 2016, 07:57:18 AM »
Curses. You are correct. I was going by the underside of the lower wing and I assumed it would be the same for the underside of the top wing. I just checked with another DV kit I have and it is as you say. Thanks for the heads up. Oh well more business for Aviattic. ::)
Offline moustique
« Reply #74 on: February 09, 2016, 01:53:30 AM »
your albatros is splendid
