Author Topic: 1/48 Eduard Albatros DV  (Read 21694 times)
Offline TobyCoulson
Re: 1/48 Eduard Albatros DV
« Reply #90 on: February 21, 2016, 04:22:19 AM »
Much head scratching and air turning blue but have finally got the top wing on,engine ancillaries added and a start on the rigging. I've been using monofilament but will have to use EZ line for the nose to wing rigging as mono broke too easily with my clumsy handling. The bottom of the lower wing will be the last to put decals on for a variety of reasons. Operation cover up is taking place down there. >:(
Offline jeroen_R90S
« Reply #91 on: February 21, 2016, 09:33:27 PM »
Looking good! Always nice to get that top wing on!
Had to fix the car and around the house, but hopefully this evening I can finish my Lozenge decals and go on to the rib tapes, as well. Thank for the inspiration :)
« Reply #92 on: February 21, 2016, 09:38:22 PM »
Geat to see that you have managed the wing assembly! Your rigging is looking good!
Offline dtomko
« Reply #93 on: February 21, 2016, 11:40:02 PM »
Looking great.
Drew
Offline moustique
« Reply #94 on: February 21, 2016, 11:42:19 PM »
very good
« Reply #95 on: February 21, 2016, 11:51:40 PM »
Shaping up very nicely so far , nice job on the rigging  :)
« Reply #96 on: February 22, 2016, 02:12:28 AM »
Looking very beautiful.
Offline TobyCoulson
« Reply #97 on: February 27, 2016, 12:46:03 AM »
Top wing now lozenged up. Taking a break for a week or so to build a Spitfire in a GB elsewhere as I can't multi task
« Reply #98 on: February 27, 2016, 01:27:55 AM »
Looking very good, Toby!  Brilliant work on the lozenge.
« Reply #99 on: February 27, 2016, 01:40:04 AM »
That is top notch Lozenge work Toby!
Offline dtomko
« Reply #100 on: February 27, 2016, 01:41:24 AM »
Lozenge looks terrific!
Drew
Offline moustique
« Reply #101 on: February 27, 2016, 03:32:01 AM »
very nice
beautiful job
Offline TobyCoulson
« Reply #102 on: March 20, 2016, 02:31:44 AM »
After a break to make an Airfix Spitfire mk lla in a GB elsewhere it's time to get on with the Albatros. Top wing decalling is now complete and  just some varnish needed to hold it all together.
Next up will be the tail assembly with control wires. Should be fun
« Reply #103 on: March 20, 2016, 08:40:25 AM »
Looks great with the roundels on! I am looking forward to your next update!
Offline TobyCoulson
« Reply #104 on: March 28, 2016, 12:18:31 AM »
I've been away from the bench of late but back to work. Control horns now fitted on to the rear elevators and I've assembled the U/C prior to fitting to the fuselage.
I've learnt a lot during this build and I'll approach the next one quite differently. Drilling out mounting points for the U/C prior to pretty much else will be one of them as trying to do it once the wings are on is not exactly a doddle!!
