Author Topic: 1/72 Lloyd 40.08 / Lk.I  (Read 17474 times)
Offline pustota
« on: December 02, 2015, 07:56:21 PM »
Good day!
I'm starting a new project, this time it will Lloyd 40.08 from scratch.
I know it will be hard, but it challenging.
The most of the model will build from 0.3 and 0.4 mm plywood.
I will be glad to get help from all of you with any information about this plane.
Here what i got:
Here what have been done so far:
Thank you.
Re: 1/72 Lloyd 40.08 / Lk.I
« Reply #1 on: December 02, 2015, 08:12:05 PM »
You have begun what must be an extremely challenging build! Using all wood construction, filing and sanding to shape, my Hat is Off to you! Well done to date!
Offline Thumbs up
« Reply #2 on: December 02, 2015, 08:23:43 PM »
Wow!!!! I shall be avidly watching your build sir.
« Reply #3 on: December 03, 2015, 12:09:13 AM »
Talk about a challenge! This should be very interesting. I'm still not sure which planet Lloyd's designers were living on though!
« Reply #4 on: December 03, 2015, 12:16:44 AM »
   Very interesting project, and as noted, a real challenge. I'll definitely be watching your progress, nicely done so far.
« Reply #5 on: December 03, 2015, 02:15:37 AM »
 Pustota,
Challenging indeed my friend. I absolutely love these old school scratch builds using wood as your main material. From your photographs I assume the wing framework is brass. That's an excellent idea and should help preventing the warping of her wings. I mention this only because I've had several ply covered wings warp badly on me. Not enough reinforcement in the wing frames or failure to properly seal the frame against moisture and the covering ply will make trouble latter on. One of those useful tricks I picked up building balsa models years ago.
A special tip of the hat to you for choosing such an unusual subject to model and medium to build in as well. Your thread shows a great promise to be most interesting and informative my friend. I'm looking forward to following your progress and learning from you. Keep up the outstanding progress and a large stock of sandpaper handy.
Offline Pgtaylorart
« Reply #6 on: December 03, 2015, 02:55:36 AM »
Scratch built in 1/72 from plywood?!! You've got my attention! What you've accomplished so far is brilliant!
George
« Reply #7 on: December 03, 2015, 04:13:24 AM »
What an awesome and challenging project, Pustota, and what an interesting subject!  Really looking forward to following this one.
Offline pustota
« Reply #8 on: December 03, 2015, 04:15:03 AM »
Thank you all for the attention to my new start. I hope to finish it, before "it" will finish me :)
Offline oldalbie
« Reply #9 on: December 03, 2015, 04:38:08 AM »
This looks like a truly challenging build.  Austro-Hungarian airplanes are some of the most curious, somewhat homely that were built.  That's why I like'em.
« Reply #10 on: December 03, 2015, 05:52:14 AM »
What an unusual looking aeroplane, and your approach to reproducing it in 1:72 scale will be quite a challenge. I tip my hat to you for using plywood for the construction of this model, I look forward to following along and seeing this project unfold.
« Reply #11 on: December 03, 2015, 06:58:58 AM »
Brilliant work so far. Will follow your build.
Online lone modeller
« Reply #12 on: December 03, 2015, 08:43:46 AM »
Gobsmacked!!! Using wood is novel to say the least and a really interesting type too. I cannot offer any help with information unfortunately as I know even less about the type than you do. But I will be following this with great interest.
« Reply #13 on: December 03, 2015, 01:28:54 PM »
very cool build
WarrenD
« Reply #14 on: December 07, 2015, 10:44:00 AM »
Wow, you're a very brave man. This is going to be epic.
