Author Topic: Cutting super thin decal strips?  (Read 2704 times)
Offline Chuckt5
« on: November 29, 2015, 07:31:38 AM »
Hello there.
I'm trying to figure out the best way to cut super thin decals strips. When I say thin, I'm thinking something like .01"/.25mm wide strips!  :o
My first thought is to make some kind of parallel blade knife that uses really thin blades. Another option would be doing it freehand with a ruler, but I would think the parallel blade set up would be better.
Any ideas?
Has anyone ever come across ultra thin blades that I could use for a parallel cutter side by side?
Thanks, Chuck.
Offline Pgtaylorart
Re: Cutting super thin decal strips?
« Reply #1 on: November 29, 2015, 07:46:03 AM »
Yes, Chuck a parallel cutter does exist. You can get one from Etsy, or probably many other places.
Here's a photo and a link:
https://www.etsy.com/listing/205804437/dual-cutter-knife-perfect-for-cutting
George
WarrenD
« Reply #2 on: November 30, 2015, 08:37:12 AM »
Thanks George!  Although taping two #11 blades is a cheaper alternative, I can see much use for this.
« Reply #3 on: November 30, 2015, 08:38:52 AM »
Thanks George for the link, I can see possibilities for that tool  ;)
« Reply #4 on: November 30, 2015, 09:53:50 PM »
I own Olfa's  Stencil Cutter.
A very handy tool to have in your box.
vB
WarrenD
« Reply #5 on: December 01, 2015, 09:57:48 AM »
Nice tool von Buckle, will it close to "zero"?
« Reply #6 on: December 01, 2015, 05:41:30 PM »
Anything is possible with a hammer!  :o
The cutter comes with 3 inserts for widths ranging from 0.5mm up to 1.5mm...I'm sure one of the inserts could be manhandled into the sort of thing you require.
Olfa Von B
« Reply #7 on: December 02, 2015, 01:16:04 AM »
Thanks for posting this "von Stencil", I'm going to see if I can find one of these, a man can never have enough tools! :) 8)
Offline Chuckt5
« Reply #8 on: December 05, 2015, 01:49:56 PM »
Thanks Von B!
I was able to jury rig a dual razor blade set up that does the same kind of thing. The thinnest strips it's able to cut are .15mm.
