Author Topic: Revell Fokker Dr.I scale 1:28  (Read 36364 times)
Re: Revell Fokker Dr.I scale 1:28
« Reply #165 on: January 30, 2016, 09:55:06 PM »
Terri and Patrick thank you very much for your very kind compliments.
Offline ondra
« Reply #166 on: January 31, 2016, 01:08:18 AM »
Getting better and better with every up-date, Martin, good job on all the improvements to the kit!
Ondra
Offline dtomko
« Reply #167 on: January 31, 2016, 06:36:08 AM »
All that work is paying off, Martin.  it looks great.
Drew
« Reply #168 on: January 31, 2016, 09:19:52 AM »
Thank you gents.
« Reply #169 on: February 08, 2016, 06:26:15 AM »
It went even further back. In addition to the painting of the surfaces, tail and other things.
Have I built from pine strips a Jack Stand and brake pads for this plane.
Unfortunately, the steel wire lies not solder even after several attempts. That's why I started from brass wire to solder the body cage. The first side is finished and the other I started with the remaining wire. New wires are ordered.
Offline jeroen_R90S
« Reply #170 on: February 08, 2016, 06:54:08 AM »
Amazing work on that fuselage framing, I'd never have the patience for that. How do you solder one bit without having the opposite end coming off? Solder with different melting points, or is there another trick...?
« Reply #171 on: February 08, 2016, 07:01:21 AM »
Nice work with the trestle and the wheel chocks Martin, and you have done a fantastic job with the fuselage framing.
« Reply #172 on: February 08, 2016, 11:02:36 AM »
Thank you Jeroen and Des.
On my soldering station you can choose different temperature. I choose 400° C and do one point to the next with a little pause.
« Reply #173 on: February 08, 2016, 12:21:55 PM »
 Martin,
Outstanding soldering skill my old friend. First class work,looking forward to the next outstanding update.
« Reply #174 on: February 08, 2016, 12:39:54 PM »
   Outstanding work Martin. The fuselage framing is quite remarkable, I don't know how you do it but I like it a lot!! :o Keep the updates coming, this gets better with every one!
Offline Pgtaylorart
« Reply #175 on: February 08, 2016, 04:33:07 PM »
Very nice work on the fuselage frame, Martin!
George
« Reply #176 on: February 09, 2016, 01:10:01 AM »
Thank you for your compliments gents.
Online RAGIII
« Reply #177 on: February 09, 2016, 01:39:11 AM »
Martin,
Impressive work on the framing! This is an outstanding build!
Offline moustique
« Reply #178 on: February 09, 2016, 01:44:17 AM »
your job is fantastic
« Reply #179 on: February 09, 2016, 02:12:52 AM »
Thank you very much Rick and moustique.
