Author Topic: Revell Fokker Dr.I scale 1:28  (Read 36547 times)
Re: Revell Fokker Dr.I scale 1:28
« Reply #150 on: January 18, 2016, 05:52:02 AM »
I started again to build on.
The axis wing on the bottom changes done.
Fuselage reduced by approximately 5mm, the end of re-sanded and filled, for the tailplane struts the holes (they are wrong !;).
Tailplane and rudder new representation of the ribs on the right site attached with thin drawn threads.
What is missing is the connection between the two rudders and the control horns.
Offline jeroen_R90S
« Reply #151 on: January 18, 2016, 06:25:19 AM »
Good looking work on this classic kit!
« Reply #152 on: January 18, 2016, 06:44:15 AM »
Thank you Jeroen.
« Reply #153 on: January 27, 2016, 04:08:29 AM »
The fuselage end is ready sanded.
Shortened lower wing at each end by just 2mm and sanded.
Reduced middle wing to size and glued the parts. For the struts attached new and old holes with putty closed.
Elevator, rudder and aileron completed. All can now be pivoted.
« Reply #154 on: January 27, 2016, 06:13:22 AM »
  Martin,
Outstanding work my old friend. She'll be one awesome Dr.I when complete. Keep up the high standard of excellence.
« Reply #155 on: January 27, 2016, 06:35:44 AM »
Thank you very much for your nice words Gregory.
« Reply #156 on: January 27, 2016, 07:13:44 PM »
Martin,
Outstanding work on those wings! Looking better with each update!
« Reply #157 on: January 28, 2016, 01:45:58 AM »
I have only just caught up with this one Martin - I remember making this as a teenager, but nothing like the standard that you are building to. This is truly first class workmanship - more detail than I can properly take in. A tribute to you supreme modelling skill.
« Reply #158 on: January 29, 2016, 01:23:49 AM »
Thank you very much for your compliments Rick and Stephen.
« Reply #159 on: January 29, 2016, 06:49:37 AM »
You have done a great job with the wing modifications, well done.
« Reply #160 on: January 29, 2016, 07:26:26 AM »
Thank you Des.
Offline moustique
« Reply #161 on: January 29, 2016, 05:01:43 PM »
you make a very hard job
« Reply #162 on: January 30, 2016, 04:20:10 AM »
Thank you moustique.
« Reply #163 on: January 30, 2016, 11:40:05 AM »
Hey Martin , so far she is looking really good on the details and corrections . keep up the excellent work !
Offline IFF1418
« Reply #164 on: January 30, 2016, 08:16:06 PM »
Hello Martin,
Your modifications are extremely well done. You are more and more becoming a famous scratch builder. Keep on this great work!
Kind regards
Patrick
