Author Topic: Revell Fokker Dr.I scale 1:28  (Read 36503 times)
Offline dtomko
Re: Revell Fokker Dr.I scale 1:28
« Reply #135 on: January 03, 2016, 09:01:22 AM »
Very nice detailing, Martin.
Drew
« Reply #136 on: January 03, 2016, 10:59:16 AM »
Thank you Drew.
« Reply #137 on: January 04, 2016, 03:25:21 AM »
Top wing inside and ailerons with control lever are finished.
Rudder before and after correction with control lever. The hull is behind even shortened. The struts are primed ready for painting.
Tailplane with elevator are too large. And with pencil correction. Must have also shortened after the hull cuts.
Middle wing inside is too long. I don`t know if I make a change quote here.
As the last of the finished engine from the rear. In the front I drilled the propeller shaft.
I think my build needs always many month work! :-X
Offline miamiangler
« Reply #138 on: January 04, 2016, 03:43:12 AM »
WOW this kit came out the year I was born ! My friend has built this kit and with a little work looks like a Fokker :). Your doing a great job . Keep up the good work !
                                                               Willi
Offline ondra
« Reply #139 on: January 04, 2016, 03:49:36 AM »
Hi Martin, sorry that I am late to this thread, did not notice it earlier.
Great job so far, will be following closely.
Ondra
« Reply #140 on: January 04, 2016, 07:04:28 AM »
Thank you very much Willi and Ondra.
« Reply #141 on: January 04, 2016, 10:08:32 AM »
Nice work on the corrections Martin  :) I also like your engine  8)
« Reply #142 on: January 04, 2016, 10:27:32 AM »
Thank you for your nice comment Terri.
« Reply #143 on: January 04, 2016, 01:33:38 PM »
looks great martin
« Reply #144 on: January 04, 2016, 01:52:23 PM »
 Martin,
She's coming along beautifully my old friend. Keep up the outstanding works.
« Reply #145 on: January 04, 2016, 05:31:51 PM »
Martin,
Your corrections continue to be fantastic! Awesome work!
« Reply #146 on: January 04, 2016, 05:56:53 PM »
All the corrections you are making is turning this into a real stunner.
« Reply #147 on: January 04, 2016, 11:28:00 PM »
Thank you very much for your very Kind comments, Scott, Gregory, Rick and Des.
Offline IFF1418
« Reply #148 on: January 05, 2016, 02:49:40 AM »
Marvellous work on the ailerons correction Martin. You keep on doing great work!
Kind regards
Patrick
« Reply #149 on: January 05, 2016, 09:43:53 AM »
Thank you for your compliment, Patrick.
