Author Topic: Wingnut Wings 1:32 Roland C.IIa (Early) Feldflieger-Abteilung (A)292b  (Read 44521 times)
Re: Wingnut Wings 1:32 Roland C.IIa (Early) Feldflieger-Abteilung (A)292b
« Reply #180 on: December 03, 2015, 11:46:06 AM »
Great job with the turnbuckles and the rear view mirror.
Offline Pgtaylorart
« Reply #181 on: December 03, 2015, 02:48:57 PM »
Nice! Gotta love Gaspatch!
George
« Reply #182 on: December 03, 2015, 08:21:39 PM »
The turnbuckles and control horns are really well done as is your scratch built mirror. The close up of the tail section really shows off the work you did with the Aviattic decals and pre and over painting. Really Awesome!
Offline Rob
« Reply #183 on: December 03, 2015, 11:51:14 PM »
Details like the mirror and the more accurate control horns really make it come alive.
Well done!
v/r,
Rob
Offline FarEast
« Reply #184 on: December 06, 2015, 08:27:43 AM »
Went to bed on Friday night with a fever of 38.9 so things weren't looking good for the weekends efforts at the workbench. However I woke up on Saturday feeling much better and with a normal temperature - although feeling rather hung over, not a fun feeling when you haven't been drinking!
So today it was time to attach the wings and start adding some of the minor details.
I also had to make custom markings for the rudder, as the size and location of the Fliegertruppe des Deutschen Kaiserreiches this was done by butchering one of the ones from the kit.
From here I could start rigging the lower wings to the fuselage, now here is the problem; this aircraft is using the C.II fuselage with the C.IIa wings  - the two aircraft are rigged slightly differently! Not only that but this aircraft uses the older airleron controls things were a little confusing!
So after going over all of the documentation I had on the Roland C.II aircraft I decided that as it was using the new wings then it would also be rigged the same as the C.IIa, however the airleron controls would need to be rigged the same as the C.II.
Obviously this is all based on logical assumption as there is absolutely no way of knowing, the only image available is taken at such an angle that none of the wires are visible.
Another strange thing about this aircraft is that some of the lines have turnbuckles at either end and this is well documented in several photos found in the Windsock Data files, Wingnut Wings manual and Roland Aircraft of WWI all of them attaching to the wing strut and front of the fuselage.
So later today I will paint up the rear view mirror and the flare rack and add the antenna to the fuselage as well as adding the last of the decals.
« Reply #185 on: December 06, 2015, 08:38:30 AM »
One of the finest examples of overall modeling I have seen in quite some time! Beautiful!
Offline Pgtaylorart
« Reply #186 on: December 06, 2015, 08:38:40 AM »
Incredible work as usual, James!
As for your questions regarding the rigging and other details; the fact that any documentation or clear photos are very scarce gives you the freedom to use your best judgement. You've probably studied this as much as anyone, who's gonna argue? As long as it's plausible. I'm sure it will be with your skill and attention to detail.
George
« Reply #187 on: December 06, 2015, 09:01:05 AM »
I couldn't agree more, James!  Truly brilliant!
« Reply #189 on: December 06, 2015, 12:06:31 PM »
A classic example of modeling at its best, you have done a superb job James.
« Reply #190 on: December 06, 2015, 09:35:25 PM »
Yep, just what I was thinking James!  You have out-done yourself, my friend!
Offline dtomko
« Reply #191 on: December 06, 2015, 10:42:07 PM »
That looks superb, James!
Drew
« Reply #192 on: December 06, 2015, 11:26:06 PM »
Fantastic job !
« Reply #193 on: December 07, 2015, 01:30:15 AM »
Absolutely brilliant work, James, a beautiful model!
« Reply #194 on: December 07, 2015, 01:41:23 AM »
Wow that is an outstanding build.
