Author Topic: Wingnut Wings 1:32 Roland C.IIa (Early) Feldflieger-Abteilung (A)292b  (Read 44724 times)
Re: Wingnut Wings 1:32 Roland C.IIa (Early) Feldflieger-Abteilung (A)292b
« Reply #135 on: November 21, 2015, 11:56:48 PM »
That looks brilliant James. Bravo!
« Reply #136 on: November 22, 2015, 12:07:23 AM »
James,
When Bo says Brilliant a modeler takes notice! I must agree whole heartedly!
« Reply #137 on: November 22, 2015, 12:13:58 AM »
It looks exellent James.
Offline Suffolk Lad
« Reply #138 on: November 22, 2015, 12:25:28 AM »
Superb result James - keep it coming,  learning all the time  ;)
Tug
« Reply #139 on: November 22, 2015, 02:04:30 AM »
     Your technique has produced an excellent effect, James, very realistic. I really like this finish you've produced on the wings, to use some of Bo's words, brilliant work! 8)
Offline Pgtaylorart
« Reply #140 on: November 22, 2015, 02:19:22 AM »
Perfect, James! It's nice that the more simple technique is the more effective.
George
« Reply #141 on: November 22, 2015, 05:46:26 AM »
Spectacular results, James!  And thanks for the tutorial on Aviattic CDL!  I love the sponged on mottle.  This is shaping up to be the best looking Roland I've ever seen.
« Reply #142 on: November 22, 2015, 06:59:30 AM »
 Outstanding James !
« Reply #143 on: November 22, 2015, 07:19:08 AM »
Well done James, you have produced an excellent result.
Michael Scarborough
« Reply #144 on: November 22, 2015, 11:51:14 AM »
Wow...James....I don't remember you having been here before but it is clear from the global response that this must be your second coming!
Really amazing!
Cheers from NYC,
Michael
Offline FarEast
« Reply #145 on: November 22, 2015, 02:07:54 PM »
Really amazing!
Cheers from NYC,
Michael
Michael, many thanks for the kind comments. I'm very new to the Hobby (about 1 year now). I basically stand on the shoulders of giants, mainly the incredible talent found here and without you guys and your willingness to share your techniques and tips I wouldn't be getting the results I am now.
Offline FarEast
« Reply #146 on: November 23, 2015, 03:44:43 PM »
So lots of small bits done today;
Radiators and windows were masked and painted - I used the lovely Uschi van der Rosten Steel polishing compound for the radiator grills while the windows received a a coat of black followed by the light blues.
After this I thought I would do some work on the propeller - Using a combinations of acrylics and oils.
But the big thing today was that I decided to crash my Roland!
Although I think that this is probably one of the easiest crashes to replicate...... just a nose down landing :D
« Reply #147 on: November 23, 2015, 05:39:10 PM »
Awesome work with your radiator and windows, and the propeller is excellent, the break looks realistic.
Offline FarEast
« Reply #148 on: November 23, 2015, 06:28:44 PM »
Des, thank you for your constant encouragement!
I'm really pleased with the propeller break and since posting I have done a little more work on the painting of it. Basically added some deck tan and then the oils and orange transparency.
As for the effects of cutting the propeller to make it look realistic it was all about the thought process - if the propeller is rotating this way how would the wood split/shatter on impact and where?
Offline FarEast
« Reply #149 on: November 23, 2015, 08:46:40 PM »
So this afternoons activities were canceled due to rain so I was able to do a little more work :D
First up finish the prop - Using the exact same colours and techniques as I followed for the actual prop I filled in the areas appropriately - only I didn't give the broken ends any varnish.
I upped the exposure rate so you can see the splinters.
With that done I decided to crack on with the wheel struts - a bit of preshading - the base colour of light blue and then a quick wash saw these done pretty quickly.
Time for a bit of dry fitting and posing.
