Under Construction
PKZ-2 Helicopter//Eduard//1:48
Pages:
3
Topic: PKZ-2 Helicopter//Eduard//1:48 (Read 6182 times)
radio
Re: PKZ-2 Helicopter//Eduard//1:48
Reply #15 on:
September 09, 2015, 06:44:17 AM »
Exellent work.
KrzysiekK
Reply #16 on:
September 10, 2015, 10:26:38 PM »
Hello again,
Finally the engine was painted and now waiting only for the wash
Now started the hardest part of assembly i.e. joining fuel tanks with the engine and keep them in the line with shaft after setting them in the frame
the result will be more/less like that
regards
K
LukasTheLight
Addicted to Wingnuts...
Reply #17 on:
September 10, 2015, 10:32:17 PM »
Hello!!!
It looks great so far!!!! Im looking forward for more!!!
Cheerio
Lukas
Lukas
radio
Reply #18 on:
September 10, 2015, 11:00:08 PM »
Looks very beautiful.
Reply #19 on:
September 11, 2015, 12:56:58 AM »
Awesome work!
coyotemagic
Reply #20 on:
September 11, 2015, 01:59:53 AM »
Excellent beginning, K! Outstanding job on the engines. Great decision to go with the Small Parts engines since this contraption is basically all engine.
Des
Reply #21 on:
September 11, 2015, 07:46:24 AM »
You are making excellent progress K, looking forward to seeing more.
halfpint33
Newbie
Reply #22 on:
September 12, 2015, 03:15:38 AM »
Outstanding job.
KrzysiekK
Reply #23 on:
September 15, 2015, 06:52:49 PM »
Hello,
During assembly It is always such a time that the critical moment must occur. In that particular built I had one once tried to set the engine in the frame at the required position. The smallstuff engine did not fit at the bottom part of the frame, which means that in order to do it easy way I had to size up the main vertical pipe. The risk to buckle the frame was taken into consideration and optimal dummy part was prepared. Now it looks better:)
regards
K
radio
Reply #24 on:
September 15, 2015, 06:56:03 PM »
Very outstanding work, K.
Now from the Croation coast for the next days.
Des
Reply #25 on:
September 15, 2015, 08:47:28 PM »
A very good fix to get the engines to fit, well done.
KrzysiekK
Reply #26 on:
September 21, 2015, 07:56:30 PM »
Hello,
in case of side absorbers I have tried to keep same appearance as on the pictures, so got rid of flat P/E part and use dummy ones.
now all small part assembly is being performed and the final rigging makes me little concern
as always
regards
K
radio
Reply #27 on:
September 21, 2015, 09:43:04 PM »
Great work as usual.
ALBATROS1234
Reply #28 on:
September 22, 2015, 03:27:18 AM »
fantastic detail keep up the great work
coyotemagic
Reply #29 on:
September 22, 2015, 07:08:16 AM »
Quote from: ALBATROS1234 on September 22, 2015, 03:27:18 AM
My thoughts exactly!
Pages:
3
Under Construction
