Author Topic: WNW Salmson 2A2/Aviattic figures: WNW Pfalz DIIIa Jasta 4  (Read 165846 times)
Re: WNW Salmson 2A2/Aviattic figures: WNW Pfalz DIIIa Jasta 4
« Reply #120 on: November 02, 2015, 09:23:29 PM »
Terrific work on the Silbergrau, Rick.  I think it looks spot-on.
The lack of seams and satiny look on the fuselage is gorgeous, my
friend.:D
« Reply #121 on: November 03, 2015, 02:25:54 AM »
Exellent painting of Silbergrau Rick.
Offline moustique
« Reply #122 on: November 03, 2015, 03:10:00 AM »
your paint is terrific
it seem you will find the best tone
Offline Oeli
« Reply #123 on: November 03, 2015, 04:01:10 AM »
Hi,
so far so good! ;)
Very good wood painting and the engines are also very nice.
I will be by your side, the next steps.
It´s interesting to see when you build two planes in the same time.
Jörg
« Reply #124 on: November 03, 2015, 06:02:20 AM »
You have achieved an excellent result with the colour mix Rick, well done.
Offline oldalbie
« Reply #125 on: November 03, 2015, 06:45:38 AM »
That was a good choice for the silbergrau Rick.  From pictures I've seen of Pfalz D IIIs it also looks like there was a lot of staining from oil, fuel and other random grime and dirt which the mechanics probably tried to clean off as best they could.
« Reply #126 on: November 03, 2015, 08:25:58 AM »
Perfect choice for the silbergrau, Rick!  It contrasts brilliantly with the metal cowling.
« Reply #127 on: November 03, 2015, 09:16:16 AM »
friend.:D
Thanks Ernie. I always appreciate your comments!
Thanks Martin!
« Reply #128 on: November 03, 2015, 09:22:47 AM »
Thanks Amigo I appreciate you dropping by and commenting!
Thanks for the comments! I agree about the dirt and oil! I have to add the Jasta 4 wound ribbon in black then I will attempt to simulate some grime using oils!
Thanks Des, Hoplahop, and Moustique! I appreciate all of your comments. The Mix looks good to my eyes and I appreciate your agreement  I think when I get around to doing my Roden DIII I might try ordering Drooling Bulldogs version to see how it looks as I had forgotten they made the color until reminded by Ondra  :-[
Offline moustique
« Reply #129 on: November 10, 2015, 01:37:53 AM »
hi Rick
do you use gaspatch turnbuckles on your Pfalz
if yes which type do you use
« Reply #130 on: November 10, 2015, 09:09:01 AM »
hi Rick
Thanks for the question. I am almost... embarrassed to say that to date I have not used Turnbuckles  ::) Something on my list to try soon. So the short answer is I don't know which Gaspatch Buckles you need but I am sure someone will chime in with the answer.
PS: A Very Small update. Just received the Excellent Aviattic Pfalz DIIIa 5 color Lozenge Decal set:
wnwsalmsonandpfalz 003_crop by Richard Geisler, on Flickr
wnwsalmsonandpfalz 002 by Richard Geisler, on Flickr
wnwsalmsonandpfalz 004 by Richard Geisler, on Flickr
wnwsalmsonandpfalz 005 by Richard Geisler, on Flickr
« Last Edit: August 14, 2017, 04:32:36 AM by RAGIII »
Offline moustique
« Reply #131 on: November 10, 2015, 08:08:06 PM »
thank Rick
« Reply #132 on: November 18, 2015, 12:42:29 AM »
I have a question reference the Salmson. What color is the cowl ring? I have failed to find any suggestion in the WNW or Pheon directions, ( Probably poor research on my part), other than those that had specific colors for squadron or personal markings. Is it French brown matching the camo with a Silver/Aluminum ring where the exhausts are, or a weathered copper? Any suggestions welcome! Just as a reminder I am doing the Pheon scheme with the Eagle and Dachshund Marking.
PS: Re read the instructions and found my own answer  :o
« Last Edit: November 18, 2015, 11:51:55 PM by RAGIII »
« Reply #133 on: November 19, 2015, 01:17:55 PM »
A small update. I have started to do the preliminary masking of the wound ribbon. This gives the rough basic location for the stripes. Next I will use tape to outline and finalize the ribbon masking, then spray them black. I have also done a little more painting on the Salmson. Next up I will do some weathering on the metal panels.
wnwsalmson 002 by Richard Geisler, on Flickr
wnwsalmson 003 by Richard Geisler, on Flickr
wnwsalmson 020 by Richard Geisler, on Flickr
wnwsalmson 005 by Richard Geisler, on Flickr
wnwsalmson 012 by Richard Geisler, on Flickr
« Last Edit: August 15, 2017, 08:28:43 AM by RAGIII »
« Reply #134 on: November 19, 2015, 08:56:31 PM »
Very nice update Rick.
