Author Topic: 1/32 WnW Felixstowe f2a late  (Read 19802 times)
Offline Pgtaylorart
Re: 1/32 WnW Felixstowe f2a late
« Reply #15 on: August 15, 2015, 03:49:12 AM »
The copper pipes look very convincing. What kind of paint did you use?
George
Hi!
I've used alclad copper. I use Alclad for metals wherever I can  ;)
Thanks for the reply, Andrew. I'll try that.
George
Offline Umlaufmotor
« Reply #16 on: August 18, 2015, 04:29:31 AM »
WOW, excellent paint.
@AndrewS
note the fractured left turnbuckle on the rear bar (by the stairs) with the number N-4545 !!
Offline AndrewS
« Reply #17 on: August 18, 2015, 06:10:47 PM »
@AndrewS
Yes, I know  :-\
They are very fragile. I think that I'll put in a couple ot gaspatch turnbuckles  ;)
« Reply #18 on: August 19, 2015, 01:32:25 AM »
Exquisite work on the interior, Andrew!  And that Felixstowe your Dad built is amazing.  And it flies!
Offline AndrewS
« Reply #19 on: August 26, 2015, 06:53:23 PM »
Hi!
I've finished the interior .
Almost all of the rigging will be invisible once inside that fuselage, but at least I know that it's there   ::)
No problem so far, this kit is a joy to build.
Meanwhile I've started to work on the engines. I've basically put on the base colors not much more.
On the block I wanted a weathered look, so I've tried the salt technique: I've sprayed the base grey, once dry I wetted the surface, randomly sprinkled some salt and I waited for it to dry. Once dry I sprayed a slightly darkned base color. When it was dry with a stiff brush I removed the salt and here's the result. It doesn't look bad to me... In real life is less evident than in pictures. I had taken some pictures of the process but they have dissapeared from my hard disk: digital carpet monster???  :o
That's all!
Andrea
« Reply #20 on: August 26, 2015, 07:21:07 PM »
You have done a fantastic job with all the internals Andrew, your choice of paint colours is excellent, and the engines are looking really good, well done so far.
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #21 on: August 26, 2015, 08:31:24 PM »
visible or not at the end, the lines are definately adding to the model and well....you will know it!
Excellent job, keep us updated :)
Think globally, act locally!
« Reply #22 on: August 26, 2015, 08:53:51 PM »
Fantastic. I have a very soft spot for this model  ;)
« Reply #23 on: August 26, 2015, 09:22:33 PM »
Outstanding cockpit work! Beautiful wood tones and the rigging looks excellent! Very well done!
Offline Pgtaylorart
« Reply #24 on: August 27, 2015, 12:32:59 AM »
Awesome!
George
« Reply #25 on: August 27, 2015, 01:10:23 AM »
Exellent work to the cockpit and engines, Andrew.
« Reply #26 on: August 27, 2015, 03:33:44 AM »
Splendid!
vB   :o
Offline AndrewS
« Reply #27 on: September 05, 2015, 11:58:46 PM »
Hi!
Back from holidays I've started to prepare the struts.
The base coat for the wood finish is on
I have a "problem" with the engine mount struts....
Are they seams lines (pointed with red arrows)? On a WnW it seems so strange  ::)
On my references I've found non good pictures of this area, so maybe someone who has already built this kit can help me  :)
Thanks!
Offline moustique
« Reply #28 on: September 06, 2015, 01:04:15 AM »
enormous job ('like the plane)
it will be a fantastic piece
« Reply #29 on: September 06, 2015, 02:30:18 AM »
Quote
yeah, looks like molding part lines to me...
