Author Topic: Siemens-Schukert D-III, Eastern Express 1/72  (Read 7760 times)
Offline vincentm
« on: July 03, 2015, 01:33:52 AM »
I still have a paint jar with a remainder of the dark red I used on my Jasta 18 Albatros, and as I like the mix of reds I made, I thought it would be a good occasion for building Udet's SSW D-III:
I have the Eastern Express kit which is a former Toko issue:
The casts made by EE from this mould are not very clean and the instructions are incomplete, the decal sheet is a shame, but the plastic is smooth with finely engraved or elevated panels and thin details.
The kit contains optional parts for either a D-III or D-IV, with two full sets of wings and struts.
The fuselage and engine cowling match the Windsock plan rather well, but the D-III's upperwing is too long in span (3+mm), and a little too short in chord (1mm). Quite impossible to fix without damaging the ribs, so...doing nothing will surely be less noticeable than the scars the fixing would leave. As for the elevator, the chord is much too short, so I'll rebuild it from scratch with rolling papers as covering fabric. The engine will also require a bit of detailing (adding the rocker rods mainly)
As usually I'll use Eduard PE for detailing the guns and adding belts to the seat and printed lozenges with lozenge rib tapes using the kit parts as a template:
Both Orion figures have been painted, the girl being Lola Zink, Udet's fiancee, photographed in front of the aircraft:
I've started the building with the painting of the wood grain using a Humbrol 93 base and oils:
Detailing the Spandaus with the Eduard PE parts: I keep only the plastic breeches and muzzles.
On the fuselage, a good part of the scribing has been filled up with CA as the panel lines are wrong and will have to be rescribed. Then I've carved the gun locations:
On the lower wing, the aileron balance horns were too short. Their end was cut away and glued back in place after adding plastic strips. The aileron hinges were built from thin Evergreen strips. The shape of the upperwing cutout was wrong and had to be corrected.
to be continued...
Re: Siemens-Schukert D-III, Eastern Express 1/72
« Reply #1 on: July 03, 2015, 01:38:38 AM »
Very good start.
« Reply #2 on: July 03, 2015, 03:43:05 AM »
Outstanding beginning work on this somewhat dated kit! Your detail work so far looks excellent!
Offline vincentm
« Reply #3 on: July 03, 2015, 09:18:38 AM »
Thanks. The 'main course' will be detailing the cockpit, which is rather empty (only a seat, rudder pedals and a stick). But the provided parts are a good base.
« Reply #4 on: July 03, 2015, 09:23:30 AM »
You have made a good start Vincent, looking forward to seeing what you do with the cockpit.
Offline Culi
« Reply #5 on: July 03, 2015, 03:41:47 PM »
I will follow this build. Its a nice little kit and great work so far.
I have the same kit, but the dcals are different, In mine set "LO" isnt included. However eastern express at least has issued those birds that others doesn't.
The process meters...  therefore so much models are stuck between start and finish
« Reply #6 on: July 03, 2015, 05:29:01 PM »
nice job,i have this kit so i will watch your technique
Offline vincentm
« Reply #7 on: July 29, 2015, 12:21:43 AM »
thanks all.
Quote
Sure, at this scale, there's no alternative except old short-run kits maybe. The main issue is the span of the wings, which is almost impossible to fix IMO.
The elevator, the shape of which was also wrong, was scratch-rebuilt and covered with rolling papers:
The paper has been painted tan-grey then varnished with Future which has tensed and hardened it:
The wings were also painted tan-grey in order to later alter the lozenge colors, the way the fabric did:
Then I've applied the lozenges, a one-piece decal on each face of the upperwing, which is rather comfortable as it also includes the rib tapes. Crosses were later added from the EE sheet. To the right: the seat with an additionnal cushion made from painted and sculpted putty:
I have then added a lip from copper wire, to the cowling's aperture:
The fuselage halves were rescribed relying on the Windsocck plans, as the original lines were wrong.
Since then, I've drilled all the blind holes in the wings and fuselage, where wire hooks will be attached:
« Reply #8 on: July 29, 2015, 04:48:36 AM »
Stunning work to this build, Vincent.
« Reply #9 on: July 29, 2015, 10:06:06 AM »
 Vincent,
Excellent works my friend. A tip of the hat to you fellas that build such wonders in such a small scale. Well Done
« Reply #10 on: July 30, 2015, 01:48:37 AM »
Outstanding start, Vincent!  She's certain to be a stunner.  Love the work you did on the tail.
« Reply #11 on: July 30, 2015, 10:07:43 PM »
You said it Bud!  Vincent you are doing an amazing job!
Looking forward to the next updates, my friend.
Offline vincentm
« Reply #12 on: August 02, 2015, 08:21:49 AM »
Thanks guys. I've started working in the cockpit. Going a little bit forward before making new shots.
« Reply #13 on: August 02, 2015, 08:28:11 AM »
Superb work on the tail Vincent, amazing workmanship in 1:72 scale. The wing lozenge looks great and you did a really good job with the seat cushion, the engine cowl is shaping up nicely, again, amazing work in such a small scale.
« Reply #14 on: August 02, 2015, 08:53:31 PM »
Gorgeous work! The tail is amazing!!
