Author Topic: Siemens-Schukert D-III, Eastern Express 1/72  (Read 7713 times)
Offline vincentm
Re: Siemens-Schukert D-III, Eastern Express 1/72
« Reply #15 on: August 14, 2015, 01:43:02 AM »
Thanks. This technique also allows partially translucent flying surfaces. I think it could be useful on SPAD fighters but it would require to scratch re-build the entire wings...
The cockpit has been detailed with plastic bits around the original EE parts. A wall has been added behind the seat and the floor was cut so the bottom of the fuselage and control cables are visible like on the real machine. Arrows point to small platic pieces used to align the fuselage halves:
Before the fuselage is closed. Instruments are slices of plastic rod with home printed instruments.
After gluing the fuselage halves, I added the lower wing. I then added the caps on top of the cowling and the hook on which are attached the cabane wires. The joints between tail planes and the fuselage have been smoothed with Milliput.
Cockpit view. Holes were drilled to let the aileron control rods go through:
The bird is now ready for painting. The undercoats roughly match materials, the wooden parts being simply painted acrylic brown. The red paint should leave various shades and possibly the lozenges, see through. Arrows show the opened airscoops and the elevator horns.
Since the last shot, I've masked the lower wings and cockpit aperture.
« Reply #16 on: August 14, 2015, 02:07:24 AM »
She's looking really good so far, Vincent. I've duly noted your corrections for mine when I get to it. Looking forward to seeing it painted.....
« Reply #17 on: August 14, 2015, 02:25:01 AM »
Wonderful work and painting, Vincent.
Online RAGIII
« Reply #18 on: August 14, 2015, 02:49:24 AM »
I have had to re check the title to make sure this is 1/72nd scale! Awesome interior and terrific construction!
Offline vincentm
« Reply #19 on: August 26, 2015, 08:38:04 AM »
Thanks Martin & RAG.
Although the model is pretty small in 1/72, the cockpit is actually roomier than that of a Pfalz D-III at the same scale, the latter having a very narrow fuselage.
After having masked the lower wings and cockpit, the thing was sprayed with dark red, and then the lozenges were fitted on the wings. The engine has only received rocker rods to detail it:
The red paint leaves the lozenges visible on the elevator, which was also probably the case on the real aircraft.
Then the cowling was added with it's hooks for the drag wires. I glued the MG's after that, adding scratchbuilt ammo feeders and a small windscreen between them.
After that, the U-hooks for the wires were added, then the rudder and it's hinges, and the control cables.
« Reply #20 on: August 26, 2015, 09:11:51 AM »
Looking great Vincent! A very colourful bird for sure.
« Reply #21 on: August 26, 2015, 09:32:14 AM »
Very beautiful Vincent.
« Reply #22 on: August 26, 2015, 10:40:31 AM »
That is a beautiful shade of red that you have used, looking forward to further updates.
« Reply #23 on: August 26, 2015, 12:50:26 PM »
Outstanding work, Vincent!  She's shaping up beautifully.
Offline stefanbuss
« Reply #24 on: August 26, 2015, 06:19:37 PM »
Hm, i can't find the information i am looking for: Obviously you didn't use the kit's Lozenge decals. Which manufacturer's decals did you use instead?
Nice choice of red, btw.
Stefan
Online RAGIII
« Reply #25 on: August 26, 2015, 08:10:41 PM »
Your SSW DIII is looking great! Beautiful work on the painting. The shade of red is excellent! Terrific work all around.
Offline ermeio
« Reply #26 on: August 27, 2015, 06:33:31 AM »
Very nice SSW, Vincent.
Bravo
Offline vincentm
« Reply #27 on: August 29, 2015, 04:04:37 AM »
Thank you all.
The red is a mix of Humbrol 60 which is rather dark and brownish, and 19, a bright gloss red.
The lozenges are home-printed. I've scanned the wings and designed dedicated decals that fit the wings including the rib tapes. It helps spare a lot of time and the lozenge colors.
As usually, I built dedicated gigs for the upper wing. Then I glued the cabane wires thorugh holes in it, and then the cabane masts.
The aileron push-pull rods were primarily put into the fuselage holes, then moved upwards to glue them under the upper wing.
Afther that, the gigs were removed and the interplane masts cemented in place:
« Reply #28 on: August 29, 2015, 08:21:20 AM »
This is shaping up beautifully Vincent, the technique of fitting the top wing was excellent.
Online RAGIII
« Reply #29 on: August 29, 2015, 09:30:34 AM »
Outstanding work on mounting the wing and locating the struts! This is turning into a Brilliant SSW in any scale!
