Author Topic: Finished: 1/48 Voisin 10 Ca2 (modified Hi-Tech kit)  (Read 75377 times)
Re: 1/48 Voisin 10 Ca2 (modified Hi-Tech kit)
« Reply #195 on: December 25, 2016, 03:21:29 AM »
I thought that some of the parts that I make are small - yours are simply tiny! Wonderful modelling.
Offline ondra
« Reply #196 on: December 25, 2016, 03:24:45 AM »
Amazing work on a very complex project, you are showing great modelling skills on this build!
Chapeau!
Ondra
« Reply #197 on: December 26, 2016, 03:09:01 AM »
Outstanding work! All of the added details are impressive. The work you did to make the lamp bulb represents just how far you are going to make this build unique!
« Reply #198 on: December 26, 2016, 05:29:31 PM »
Fine jewellery!
Offline huberlu
« Reply #199 on: February 07, 2017, 07:31:08 AM »
Hello,
I have finished all the rigging (almost). There remain the flight control cables, brakes and other stuff to stick.
The flat rigging are in "evergreen" as thin as possible and stretched with an embers (match). The hardest part is to stick them securely.
The rigging between the wings are made of fishing line as well as those on the tail
The tail is fixed with a small piece of steel wire that fits into the brass rod and into the pierced wing. To my surprise it's pretty solid. I have not broken it yet despite the many manipulations.
 Only worries is the size of the wings, they distort when I turn the plane and the rigging take off. The wings tend to make the swing around the attachment of the undercarriage under the fuselage.
The big cockroach on the back:
It is for gluing flat shrouds ...
The empennage will be glued at the end, fixed on two half-washers from the kit:
The rudder I had painted, with love and the greatest care, is ... black on all the pictures I've seen. So I covered with black and I took the opportunity to let appear the colors of the undercoat. The serial is fictitious and the font too "modern". The decals come from Corsair Heller.
The pipes supplying the engine with fuel made of lead wire glued.
Huberlu
« Last Edit: February 08, 2017, 02:40:17 AM by huberlu »
Offline jamieg
« Reply #200 on: February 08, 2017, 03:37:14 AM »
That is really shaping up beautifully, Huberlu.
Jamie
« Reply #201 on: February 08, 2017, 03:58:09 AM »
What a super model. I do hope that you will not accidentally damage it before it is complete - that would be a disaster!
« Reply #202 on: February 08, 2017, 04:25:01 AM »
Awesome build, looking really good.
« Reply #203 on: February 08, 2017, 04:54:58 AM »
This is just "wooooooooow"!!!
« Reply #204 on: February 09, 2017, 12:49:15 AM »
I seeme to have missed this last update until now. WOW! I love the continuing excellence of the build! The rigging, tail assembly gear, and especially the rudder showing the chips revealing the original colors are AWESOME!
« Reply #205 on: February 09, 2017, 12:59:37 AM »
Huberlu,
   Your detail is truly spectacular, this is really an impressive model. I'm also really impressed with your weathering and wear representation, twice as difficult to replicate on a mainly black finish. Great work, a beautiful model already!
« Last Edit: February 09, 2017, 02:26:45 AM by lcarroll »
« Reply #206 on: February 09, 2017, 02:04:32 AM »
I quote Lance, the worn black paint is an idea worth of a modeling genius!
Not to speak about the remainder of the impressive work we can admire here...
Antonio
Offline huberlu
« Reply #207 on: February 09, 2017, 04:51:09 AM »
Thank you ! :)
« Reply #208 on: February 12, 2017, 05:29:23 PM »
Very nice louis. I have enjoyed following this build. It is another one of your masterpieces
« Reply #209 on: February 12, 2017, 05:48:39 PM »
My thoughts exactly.
