Author Topic: Albatros D.Va Paul Bäumer Jasta 5, 1/144 scratchbuild  (Read 27848 times)
Offline ondra
Many thanks for the confirmation, Red Baron.
I assume the fairings on the lower side of the upper wing looked the same as on the upper side, correct?
Yeah in 1:144 the fairings will be basically identical top and bottom, although in fact they are not quite so in 1:1 (or 1:32). There are excellent detail photos of the fairings on the WNW site in the archive photos section of the DV kit page...
Michael Scarborough
This is simply astounding.
Bravo, Ondra!
Cheers from NYC,
Michael
Offline ondra
Hello everybody, once again many thanks for your support and positive comments, I will admit I always smile like an idiot while reading them. :)
Please let me share the photos of Bo's Mercedes D.IIIa in 1:144, now in black primer which shows much more clearly, how incredible they look. I am really astonished by what Bo has created.
I had no time to get to my workbench at the weekend, so only a very slight progress on the build:
I prepared the sandwich of black and white styrene for the carved propeller:
...and made very first steps on the Spandaus:
Ondra
Very beautiful.
WarrenD
OK, in my ignorance, I must ask: why a B&W sandwich for the propeller?
Offline ondra
Fair point, Warren, sorry for the missing description.
I always admired the gorgeous carved laminated props on larger scales and was wondering how to achieve a similar result in 1:144. As I am not really good at working with brush, the results of attempts on painted layers of dark wood did not look good.
As I can not use light and dark wood in this small scale, I use thin sheets of white and black plastic welded together in a B&W sandwich, here a few photos of the prop I made for the Hansa-Brandenburg:
This was the first attempt and I had to admit that the particular layers were way too thick, but after using thinner plastic, I was quite satisfied with the result:
Far from perfect, but still better than previous pieces.
Ondra
WarrenD
OK, so you are making the sandwich, carving the prop, and then applying a thin stain or thinned paint?
I ask, because in 1/72nd, I cannot use layers of wood either. (I tried, but I wasn't able to source it.)  I'd like to try this in 1/72nd.
Offline ondra
You are right, I just apply a thin coat of oil paint (it was yellow ochre in case of the H-B D.I) in the same way as creating the wood effect.
I think this method could work well for your scale, should you need any support, just let me know, will be happy to help.
Ondra
it is amazing what you acheive in such a tiny size. cheers.
WarrenD
I'm sure going to try it Ondra, thanks so much for the explanation.
It's an extremely clever idea, btw Ondra. 10 bonus points awarded.
Offline ondra
Thank you very much for the compliment, sir. :)
The idea was inspired by Sergey Mertens, a few months ago he explained me the "colour perception" from the artistic point of view and that brought me to this.
The very initial intention was to use a sandwich of yellow and red sheets - you need warm colours as brown (which is the final colour you wish) is a warm colour too. Unfortunately, I have not found a proper source for styrene sheets in the colours I need. That's why I had to use black and white, even for the black styrene I have to use coffee-to-go caps. :) Actually I broke all the rules Sergey explained me as I am using cool colour (white) under warm colours.
To WarrenD: If you want to try this method, I can really recommend you to search for yellow and red plastic sheets, the result will look much better. I you are fortunate to find a place to buy them, would be great if you could let me know.
WarrenD
Thanks for that Ondra, I'll keep an eye out for those colors!
Now, hmmm . . . . . what would the lamination thickness of an Axial prop on a Fokker Triplane come out to in 1/72nd . . . . . ::)
Something around .010", no?
