Author Topic: Albatros Dva 1/16  (Read 99380 times)
Re: Albatros Dva 1/16
« Reply #510 on: September 06, 2017, 07:32:05 AM »
Martin, when it comes to your work, all my expletives fall short.  The long and short of it is, you are the Master!
« Reply #511 on: September 06, 2017, 07:46:19 AM »
Martin, your work leaves me (and I am not alone) speechless.  Simply magnificent.
« Reply #512 on: September 06, 2017, 08:04:41 AM »
Total agreement from this Amigo!
Offline boggie
« Reply #513 on: September 06, 2017, 12:12:53 PM »
Wow Martin.
Your creation is more than a model, it's miniaturization perfection!
More please  :)
« Reply #514 on: September 06, 2017, 04:41:30 PM »
Wow....just wow!!!
Offline davec
« Reply #515 on: September 06, 2017, 08:13:36 PM »
Tremendous.  Beautiful work with the brass.
Offline UFAG
« Reply #516 on: September 07, 2017, 06:00:58 AM »
OFF TOPIC...this will be my next project after the Alb or beside the Alb.
Only, I wil build the whole plane behind it in 1/18...( okay, what am I thinking again..)
Offline UFAG
« Reply #517 on: September 07, 2017, 06:02:35 AM »
« Reply #518 on: September 07, 2017, 08:27:17 AM »
I got it..!! RAGIII = Rick..!! Sorry for the brain mist..
You have it correct  ;D I have explained this before but there are newer members now. RAGIII is simply my initials: Richard Andrew Geisler III.
Offline UFAG
« Reply #519 on: September 09, 2017, 06:16:20 AM »
Offline UFAG
« Reply #520 on: October 21, 2017, 10:48:33 PM »
Dear forum members,
Some time things in life do happen, some times recoverable, some times it is not.
In this specific case, it is unrecoverable.
During a move from one room to another ( stairs ), despite carefull handling, the assembly had a mind of its own and went down the stairs ending up in a crashed wreck...!! In a long past, I had havoc before with a model ( WWII Shiden George)...but that model was recoverable.
The Albatros Dva unfortunately is not. I have worked on the model for the last 15 years with pauses in between, after all that work, it is a little bit hard to comprehend. I am not in shambles though...will clean up the working place and give my thoughts on the next project..enough to go for. In the mean time, I will follow your fantastic builds.
I'll be back.
Offline UFAG
« Reply #521 on: October 21, 2017, 10:50:31 PM »
Offline RLWP
  • Bodger
« Reply #522 on: October 21, 2017, 11:02:22 PM »
Hi Martin,
if you are giving up on this, will you be selling on the crashed kit?
Offline UFAG
« Reply #523 on: October 21, 2017, 11:17:46 PM »
Sorry Richard, if there was any hope to fix the lot, I would have done so.
All is already in the thrash bin. All I saved is the engine and the hand carved prop...just to rember.
Offline RLWP
  • Bodger
« Reply #524 on: October 21, 2017, 11:31:55 PM »
Then there is still hope.
Time to park this and let it bounce around your mind for a while
After all, there may be another use for that engine...
