Under Construction
Scratch builds
Blackburn Heavy Monoplane
Pages:
9
10
11
12
13
Topic: Blackburn Heavy Monoplane (Read 33457 times)
Des
Re: Blackburn Heavy Monoplane
Reply #135 on:
March 18, 2015, 06:16:53 PM »
Thanks LM and Bob for dropping by and having a look, your comments are always appreciated.
Thumbs up
Reply #136 on:
March 18, 2015, 07:32:52 PM »
Quote from: bobs_buckles on March 18, 2015, 06:17:59 AM
Hi Des,
You need a sculptor to make up some Dastardly and Mutley figures
Great work!
VB
Clunk must have had a hand in it somewhere!
Culi
Jr. Member
Reply #137 on:
March 18, 2015, 11:03:46 PM »
Great work. I will remain silent and continue enjoying.
The process meters... therefore so much models are stuck between start and finish
Love the self
Reply #138 on:
March 18, 2015, 11:29:30 PM »
This build reminds me of this video
https://www.youtube.com/watch?v=jQhh__67Avs
Some pieced together with stuff just laying around ....
Des
Reply #139 on:
March 19, 2015, 07:40:48 AM »
Thank you Jak and Terri for your comments, they are much appreciated.
Terri, great little video and I can quite easily see why you connect my model to this film, it would fit in perfectly with the other bits and pieces aeroplanes
Royston
Full Member
Reply #140 on:
March 20, 2015, 12:57:05 AM »
Very good Terri
Love the self
Reply #141 on:
March 20, 2015, 11:59:54 PM »
Your welcome guy's . I watch the video from time to time and always get a chuckle out of it .
radio
Reply #142 on:
March 21, 2015, 09:49:17 AM »
Thank you for show us this film Terri.
Des
Reply #143 on:
March 21, 2015, 11:54:27 AM »
The wing has been formed by gluing two sheets of 0.4mm styrene cut to size, then they were wrapped around a piece of 56mm PVC tube and taped with duct tape to obtain the correct airfoil shape. It was left for a full 24 hours to dry thoroughly before the tape was removed and the wing now retains its shape and the curve adds stength. I still need to sand the leading and trailing edges and the tips, then all the rib tapes need to be added. These pictures show the unfinished wing just sitting roughly in position, it is only a small wing with no dihedral.
jknaus
Reply #144 on:
March 21, 2015, 12:42:09 PM »
Just so cool. Loving this build Des.
James
Reply #145 on:
March 21, 2015, 11:28:42 PM »
Des,
You make things look so easy.. I am always amazed at the quality and speed of your scratch builds!
radio
Reply #146 on:
March 21, 2015, 11:55:56 PM »
Fantastic Des.
lone modeller
Reply #147 on:
March 22, 2015, 04:04:50 AM »
What more to add? Ah I know! Bravo!!!!!!
Nigel Jackson
Reply #148 on:
March 22, 2015, 05:58:04 AM »
It just gets better and better, Des, and is so impressive.
best wishes
KitRookie37
Sr. Member
Reply #149 on:
March 22, 2015, 06:09:42 PM »
Hello gentlemen,
It's fitting as well as possible. Very good work, you're an artist Des.
Best regards.
Alain.
Use the force, Luke.
Pages:
9
10
11
12
13
Under Construction
Scratch builds
