Author Topic: Blackburn Heavy Monoplane  (Read 33455 times)
Re: Blackburn Heavy Monoplane
« Reply #150 on: March 22, 2015, 06:44:39 PM »
My many thanks and appreciation to James, Rick, Martin, LM, Nigel and Alain for your very kind comments.
Offline ondra
« Reply #151 on: March 22, 2015, 07:04:18 PM »
Hi Des,
there are modellers and then there are artists. You belong to the artists group. ;) I really admire your scratch building skills.
Ondra
WarrenD
« Reply #152 on: March 23, 2015, 12:27:23 AM »
A wonderful scratch-build as always Des.
« Reply #153 on: March 23, 2015, 06:22:18 AM »
Thank you Ondra and Warren for your much appreciated comments.
Offline Royston
« Reply #154 on: March 23, 2015, 08:14:30 AM »
Taking shape nicely Des.
What do you intend on using for the rib tapes
Roy
« Reply #155 on: March 23, 2015, 08:27:17 AM »
Thanks Roy.  For the rib tapes on the top of the wing I will be using 1.5mm half round styrene strips and under the wing will be 0.5mm Bob's strippers.
Offline Royston
« Reply #156 on: March 23, 2015, 07:22:19 PM »
interesting, but leads to another question Des.
Why the difference in width for upper and lower.
Roy
« Reply #157 on: March 23, 2015, 07:47:48 PM »
I was left wondering as well after looking at the very few photos I have of the original aircraft. The top ribs were very pronounced with a scallop effect of the fabric between each rib whilst the bottom of the wing has very taut fabric and only a small indication of the ribs. The 1.5mm half round styrene I used on the top wing will be reduced in size once all the sanding is completed and the scallop effect highlighted.
Offline Royston
« Reply #158 on: March 23, 2015, 09:35:03 PM »
Cheers Des, that explains it nicely thanks
Roy
« Reply #159 on: March 26, 2015, 01:53:11 PM »
very nice des, i wonder if you keep this up where you will put all these masterpieces.
« Reply #160 on: March 29, 2015, 12:26:24 PM »
Thanks very much Roy and Scott for taking an interest in my project, your comments are much appreciated.
I purchased two sets of Spad spoked wheels from John Vojtech at Scale Spokes, they were on special for $20 per set but even at their full price of $26 they are excellent value. The wheels have been fitted to the aircraft, I needed to make the front sing arm suspension assembly for the front and also the sprung frame for the rear wheel. I still need to add the bungee cords to the front suspension. The wing is also nearly ready, the ribs have been added and the painting done, I have fitted the top rigging single ended turnbuckles but still need to fix the bottom ones.
Offline KitRookie37
« Reply #161 on: March 29, 2015, 05:23:19 PM »
Hello gentlemen,
Again, a masterpiece !!! Yeah !! I like it.  :D
Best regards.
Alain.
Use the force, Luke.
Offline ermeio
« Reply #162 on: March 29, 2015, 06:56:23 PM »
it is turning out into a magnificent masterpiece, Des
A great work!
« Reply #163 on: March 29, 2015, 09:09:34 PM »
Your builds just keep getting more mind-blowing, Des!
Leaf springs? Oh man! I can't wait for the main rigging to
begin. :D
« Reply #164 on: March 29, 2015, 09:56:48 PM »
Curiouser and curiouser.....(plagiarism? Me?) Lovely work as usual Des!
