Author Topic: Voisin III  (Read 93737 times)
Re: Voisin III
« Reply #75 on: May 15, 2012, 09:16:40 AM »
Exquisite work Des. You must have the patience of a saint my friend. How you manage to complete such clean and precise work is beyond me. I'm beginning to think that your hands must be 1/32 scale.  ;D
Looking forward to seeing more!
Re: Voisin III
« Reply #76 on: May 20, 2012, 09:22:14 PM »
This aircraft has the unusual rigging arrangement of cross bracing on the underside of the top wings, I did this with 0.12mm monofilament connected to eyelets fixed to the wings, each line also had turnbuckles. This rigging had to be completed before the wings could be fixed to the airframe. There are 33 eyelets fitted to the bottom of each top wing, so that will amount to a lot of rigging.
The overhead lighting has changed the colour of one wing  ???
« Last Edit: May 20, 2012, 09:32:55 PM by Des »
Re: Voisin III
« Reply #77 on: May 20, 2012, 09:30:44 PM »
The top wings mounted very easy, the mounting pins proved adequate to support the wings and after the addition of the glue the wings held their own weight without added support. The struts are also fitted, the protruding strut ends will be trimmed after the fixing nuts are fitted. The rigging has commenced, again I am using 0.12mm Maxima Chameleon fishing line, once each line is fitted they are painted with Mr Metal Color Stainless, all rigging and turnbuckles are fixed with CA (super glue). All I have done so far is the forward rigging on the two inboard bays, this took all day.
Offline Ian from Doncaster
Re: Voisin III
« Reply #78 on: May 20, 2012, 09:38:12 PM »
This only gets better Des, simply stunning rigging work here...
Offline Whiteknuckles
Re: Voisin III
« Reply #79 on: May 20, 2012, 09:49:45 PM »
Your a true inspiration Des - this is a true work of art!!
Eternal Apprentice
Re: Voisin III
« Reply #80 on: May 20, 2012, 11:23:55 PM »
I have been asked to give a size comparison of the Voisin, so here it is compared to a WnW Albatros, the wingspan difference is quite obvious but the height of the two aircraft is pretty much the same.
Re: Voisin III
« Reply #81 on: May 21, 2012, 12:19:22 AM »
  Des,
Your Voisin III sure makes the Albatros appear down right tiny. Looking forward to your next awesome update my old friend.
Re: Voisin III
« Reply #82 on: May 21, 2012, 12:41:53 AM »
That is one big span. Happy continued rigging, its spectacular so far.
Offline specialops
Re: Voisin III
« Reply #83 on: May 21, 2012, 01:14:11 AM »
A truly magnificent build Des I look forward to it's completion.
Best Regards
tonyb
Re: Voisin III
« Reply #84 on: May 21, 2012, 02:04:45 AM »
Oh, my, Des!  That is a lot of rigging!  You're doing a masterful job of it, though, as usual.  When I saw the photo of your work area (very nice, by the way) and saw this lovely bus sitting on your desk, I was compelled to pull out my 1/48 High-Tech Voisin kit and take a look at it.  I was very tempted to get her started by this brilliant project of yours.  That underwing rigging has given me pause, though.  Whew!  That's a lot of turn-buckling, mate.
The size comparison is interesting, too.  Yeah, the wingspan's huge, but the nacelle is tiny compared to the Albatros fuselage.  Such a vast difference in design.  Very cool.
Offline phs Paddy
Re: Voisin III
« Reply #85 on: May 21, 2012, 06:43:31 AM »
Wonderful Des! It's really a joy to follow your progress.
Paddy
Offline Old Man
Re: Voisin III
« Reply #86 on: May 21, 2012, 07:06:53 AM »
This is coming along wonderfully, Sir!
Reference quality stuff.
Offline NinetythirdLiberator
Re: Voisin III
« Reply #87 on: May 21, 2012, 02:42:41 PM »
Des,
HOLY YOU KNOW WHAT!!   :o :o :o
I was pleased I squeaked by basically using your tutorial with slight modification on my 48th Roden Bristfit.
Your Voisin is true modeling at its best.  I so look forward to seeing your posts on this great plane.
Dan
Offline Trackpad
Re: Voisin III
« Reply #88 on: May 22, 2012, 08:57:30 AM »
What they've all said, what we've said before, what we'll probably keep right on saying for ever and ever, amen: "You da Man!!" Excellent work, Des!  ;D
Cheers!
Re: Voisin III
« Reply #89 on: May 22, 2012, 10:11:58 AM »
Knowing how you like to rig, and with the amount of rigging I'm seeing just between the wings, now I know why you chose this project as your first scratch building project. The rigging sure does bring the aeroplane to life.
Superb engineering and workmanship Des!
