Under Construction
Scratch builds
Voisin III
Pages:
10
11
12
13
15
Topic: Voisin III (Read 93804 times)
Des
Re: Voisin III
Reply #150 on:
June 11, 2012, 02:01:52 PM »
I have added bomb racks and bombs to the sides of the Voisin. The racks are made from 0.5mm plastic card and were made to suit the bombs which are left over from previous builds, they are pretty close to the correct size and shape. I add 0.5mm brass tube to the nose of the bombs. I painted the bombs with Gunze off white, the tubes are done with Mr Metal Color Stainless and the red band is Humbrol Ferrari red. The racks are painted with Gunze Light Brown. Once all the paint has dried I will fix the bombs to the racks and the racks to the fuselage. Having the racks located where they are would certainly make it difficult for the crew to board the aircraft.
Whiteknuckles
Re: Voisin III
Reply #151 on:
June 11, 2012, 02:40:56 PM »
Immaculate as always Des
How did the crew get in? was there a ladder or foot rungs/hand holds?
Eternal Apprentice
Des
Re: Voisin III
Reply #152 on:
June 11, 2012, 03:09:01 PM »
Thanks Andrew. There were foot steps on the two undercarriage tubes which run fore and aft from the centre of the fuselage, I have yet to add these, from all the photos I have seen there were no hand holds.
Last Edit: June 11, 2012, 03:11:06 PM by Des
Jose Chaica
Jr. Member
Jose "Von Muttley" Chaica
Re: Voisin III
Reply #153 on:
June 11, 2012, 04:37:11 PM »
Nice bomb racks... these are the details that make your build stand out even more!
IMO the bombs were probably loaded only after the crew got on board (as seen in so many other period pics)... that would make sense.
Last Edit: June 11, 2012, 04:39:27 PM by Jose Chaica
Jose Chaica, from Portugal.
pepperman42
Re: Voisin III
Reply #154 on:
June 12, 2012, 10:54:35 AM »
The final details are really bringing this one to life!!!
Vladimir Ziska
Full Member
Re: Voisin III
Reply #155 on:
June 16, 2012, 05:48:09 AM »
Hi Des,
it is very, very, very cool. Best works with multimedia materials.
Vladimir
www.nordlandmodels.com
www.oldpropeller.com
JastaB
Jr. Member
Re: Voisin III
Reply #156 on:
June 16, 2012, 05:56:59 AM »
Des,
Your Voisin is magnificent!
Tim
Chris Johnson
Re: Voisin III
Reply #157 on:
June 16, 2012, 08:54:01 AM »
It just keeps getting better and better Des.
Des
Re: Voisin III
Reply #158 on:
June 17, 2012, 02:01:06 PM »
I have completed the under wing rigging and most of the control rigging. The exposed cross bracing on the under side of the bottom wing required a turnbuckle on each individual line, the same as under the top wing. The rudder and elevator control cables run through a triple pulley, I needed to make four of these pulleys, two are mounted under the fuselage and one each on the bottom tail booms. All this rigging is on the underside of the plane so very little of it will be seen once it is back on it's wheels.
bobs_buckles
Freedom isn't free.
Re: Voisin III
Reply #159 on:
June 17, 2012, 05:47:39 PM »
A spiders web if ever I saw one. Truly awesome work, Des
Give that man a drink!
BVB
Jose Chaica
Jr. Member
Re: Voisin III
Reply #160 on:
June 17, 2012, 06:17:16 PM »
Such a beauty!!!
It´s simply amazing... simply, amazing!
GAJouette
Re: Voisin III
Reply #161 on:
June 18, 2012, 01:19:12 AM »
Des,
Congratulations you've some very well trained rigging spiders mu old friend. Awesome rigging!
Chris Johnson
Re: Voisin III
Reply #162 on:
June 18, 2012, 08:38:59 AM »
This is incredible Des. I've never seen such complex rigging, not to mention such a fine, meticulous, job of it. I'm blown away by your craftsmanship. Please tell us how you made the pulleys as they look every inch the part.
uncletony
Re: Voisin III
Reply #163 on:
June 18, 2012, 09:27:29 AM »
The control cable rigging with the pulleys etc is so cool and your fantastic craftsmanship lets us see and grasp how the thing actually worked. And not even just grasp, but get excited about in all its crazy rube goldberg wonder. Marvelous.
Youtube Channel
Whiteknuckles
Re: Voisin III
Reply #164 on:
June 18, 2012, 11:03:08 AM »
Des, those pulleys are outstanding and meticulous - I'll echo Chris' request for a 'how to' please.
Also, I noticed rigging lines going into the wheel hub, these birds must have been quite sturdily braced.
Eternal Apprentice
Pages:
10
11
12
13
15
Under Construction
Scratch builds
Voisin III
