Author Topic: Question about colored doped linen....  (Read 8779 times)
Offline JoeDxMB
« on: June 14, 2012, 08:35:44 AM »
When depicting a CDL fuselage, the same basic color is used on the interior exposed linen .
Now, what about fuselage linen that is painted with  other than clear dope? Does the color bleed throgh to the cockpit  side.
Example... ....what about a fusalage that is painted entirely of silver dope.  How would one depict the interior linen? Would it be a shade of silver?
Did they perhaps first usually  seal the linen with clear dope before over painting it with color?
Offline kornbeef
Re: Question about colored doped linen....
« Reply #1 on: June 14, 2012, 09:03:30 AM »
Theres some evidence of bleeding through yes though to what extent I wouldnt know.  Shots of Swordfish and One or two of Sopwiths (I'm pretty sure I've seen internal shots of a Pup or Tripehound) have a reddish tint to them as the linen was primed with red oxide coloured first it's said.  I for one though tend to make the inner face of the linen somewhat paler than the thickly doped exterior.
Hope this helps
Keith
Offline JoeDxMB
« Reply #2 on: June 14, 2012, 09:27:08 AM »
Hope this helps
Keith
Yes, it definately does help.  :)
BTW,  I plan  on depicting  an all silver (excepct for a red  cowl)  Morane Sauliner A-1.
« Last Edit: June 14, 2012, 09:43:33 AM by JoeDxMB »
Offline JoeDxMB
« Reply #3 on: June 14, 2012, 09:36:11 AM »
In the case of Alied aircraft, the later, so CDL on the inside, PC10 / 12 on the outside.
I'm not shure exactly what you mean.... can you please elaborate a bit?
Offline JoeDxMB
« Reply #4 on: June 14, 2012, 12:40:55 PM »
I asked the same question a while back on another site and someone was good enough to post up pictures that showed that the inside remained a light CDL colour even after the outside was coated with PC10 colour, presumably as a result of the linen being sealed / shrunk first.
OK.. that is what I suspected in my OP.
Thanks .  :)
In any event, I guess  it's like a lot of things in WW1 aircraft........ there is more than one way  that would be historically accurate .
« Reply #5 on: June 14, 2012, 01:04:17 PM »
Thanks .  :)
You've made a very profound and , IMHO, accurate statement. In my 50+ years of involvement in, albeit to varying degrees of participation,, WWI Aviation the only thing one can be sure of is.................were not sure!!  I really enjoy getting into the "weeds" on various questions and interpretations, and there usually is a correct answer. On the other hand, I never disregard anyone else's interpretation as history and the passage of time have a way of confusing the facts. Learn as much as you can but don't hesitate to apply informed interpretation of the available information; who can call you wrong?
Offline Ian from Doncaster
« Reply #6 on: June 14, 2012, 05:41:00 PM »
...... On the other hand, I never disregard anyone else's interpretation as history and the passage of time have a way of confusing the facts. Learn as much as you can but don't hesitate to apply informed interpretation of the available information; who can call you wrong?
This is precisely why I don't get too deeply involved with historical accuracy (not yet, still learning modelling techniques) as there is often perhaps more than one correct answer, or no proven correct answer.
« Reply #7 on: June 14, 2012, 09:57:46 PM »
 Those documenting "current" history should note this thread. In 30 yrs are modellers going to be asking "What was the colour of the .... on an F16?"
Offline Whiteknuckles
« Reply #8 on: June 14, 2012, 10:41:18 PM »
At the rate the JSF is going, F16 variants will still be flying 30 years from now ::) :o
Eternal Apprentice
« Reply #9 on: June 14, 2012, 10:56:24 PM »
Take a look on the Vintage Aviator site:
http://thevintageaviator.co.nz/projects/re8-reproduction/vintage-aviator-re8
There are some good shots of the RE8 showing both the exterior PC10 and interior, almost white linen, in the same shot.
« Reply #10 on: June 16, 2012, 01:36:17 PM »
i would think that even if a craft was just doped linen that the interior would be a couple shades lighter. the dope as i understand doesnt completely soak thru the fabric so on the outside it would be a more yellowy cream color due to the dope which is like a varnish and the interior almost white. same on a pc-10 craft it seems like the photos ive seen of original a/c as well as replica the interior linen is usually very light.which to me makes sense.
« Reply #11 on: June 16, 2012, 05:46:21 PM »
Does this mean that aircraft primarily painted in PC10 were doped first, to tighten and seal the fabric, before adding the top colour?  That is what I thought but have never been sure.
Offline Jim52
« Reply #12 on: June 16, 2012, 10:33:52 PM »
Ian,
     I think that that is correct. Dope to shrink the fabric and then color coats. However,
I seem to recall a post by DSA on the 'Drome stating that there was varnish between the
Dope and the color coats. The Varnish was used to actually seal the fabric. I very well
may be mistaken, though.
Jim
Offline JoeDxMB
« Reply #13 on: June 17, 2012, 01:41:50 AM »
I just thought of something.....
Can we assume  that clear dope was applied at the factory to all aircraft and the individual squadron markings/ colors were applied in the field?
« Reply #14 on: June 17, 2012, 03:45:15 AM »
In the field or definitely after the initial doping etc. Thats a good assumption and therefore yes the markings would possibly take on a slightly different tone/sheen/texture but in scale that, I suspect, would be minimal.
