Author Topic: SSW D III early (old Eduard kit)  (Read 25340 times)
Re: SSW D III early (old Eduard kit)
« Reply #15 on: January 12, 2015, 12:04:19 AM »
Will be following your build  ;)
Offline BigBlue
« Reply #16 on: January 12, 2015, 12:31:23 AM »
Good luck, Martin!  I look forward to seeing your progress.
Offline IFF1418
« Reply #17 on: January 12, 2015, 12:54:22 AM »
Another daring project Martin. Good luck to you. This will be nice to follow!
Kind regards
Patrick
Offline Jorgo
« Reply #18 on: January 12, 2015, 02:19:00 AM »
Good luck to you! You are a courageous man 👍 that old Eduard kit is not the easiest one...
Kind regards, Jörg
« Reply #19 on: January 12, 2015, 05:10:15 AM »
Thank you for your positiv comments Terri, Chris, Patrick and Jörg. 8)
« Reply #20 on: January 12, 2015, 05:18:15 AM »
A Little update: the new rudder is ready.
Some changes to the fuselage: the air intake open, cool intake cut away, new structure inside beginning.
« Reply #21 on: January 12, 2015, 05:23:40 AM »
Nice start Martin!
Offline jamieg
« Reply #22 on: January 12, 2015, 05:29:49 AM »
I see you are not going to use the amazing handy dandy million and one fold PE interior. Good plan; I remember fighting that thing tooth and nail before finally getting it into the fuelage. I had been out of modelling for about fifteen years when I saw this kit in a store. I've always like the SSW D.III/IV because it looks like a beer keg with wings, so I bought it. Probably not the best kit to discover the joys of PE on. But I managed to get it built.
« Reply #23 on: January 12, 2015, 07:04:22 AM »
Thank you Rick and Jamieg.
« Reply #24 on: January 13, 2015, 05:32:43 AM »
Both body insides so far possibly finished and primed. New parts made and the first engine ventilation below open.
Etch parts become so far it goes substituted!
Offline stefanbuss
« Reply #25 on: January 14, 2015, 02:46:32 AM »
Hm. I don't like the way you have opened up the first ventilation cover - it looks a bit brutal to me.
Stefan
« Reply #26 on: January 14, 2015, 09:21:30 AM »
Ok Stefan you are right, but I think there is no other way to open the Ventilation. At last it will be sanded.
« Reply #27 on: January 14, 2015, 09:37:37 AM »
The next parts finished, like flaps, tank and mg-belt box.
Also paints the first parts with plywood colour. I do not like the structure.
« Reply #28 on: January 14, 2015, 11:22:47 AM »
Hi Martin  ,
Opening up the gills on the chin pan is not an easy task . I did my by thinning down the inside so the area was only 1mm in thickness . Calipers are for handy for this for measuring the thickness as you go . Digital ones are even better .
I opened them up using a scribing tool and finishing with a #11 . At this stage the plastic is very thing and easy damaged .
« Reply #29 on: January 14, 2015, 08:23:29 PM »
Thank you Terri.
