Author Topic: SSW D III early (old Eduard kit)  (Read 25418 times)
Re: SSW D III early (old Eduard kit)
« Reply #45 on: January 18, 2015, 06:13:02 AM »
Beautiful update, Martin!
« Reply #46 on: January 18, 2015, 06:47:01 AM »
Thank you Bud.
Offline IFF1418
« Reply #47 on: January 18, 2015, 08:17:37 PM »
Hi Martin, very good progress! Do you happen to sleep sometimes?  ;)
Kind regards
Patrick
« Reply #48 on: January 18, 2015, 09:07:43 PM »
Thank you Patrick.
This is my great hobby and so I work about one until four hours every day. 8)
« Reply #49 on: January 19, 2015, 05:55:47 AM »
In the fuselage halves I glued the altimeter and compass on completion.
The tank is mounted on the front part.
In addition, here are lower surfaces separated and other parts attached to the bottom.
Offline NinetythirdLiberator
« Reply #50 on: January 19, 2015, 11:35:01 AM »
Great work, Martin.  That SSW is one of my favorites.  I think I might spring for the new kit but yours is real modeling!
Excellent.
Cheers from Tacoma Washington, USA
Dan
« Reply #51 on: January 19, 2015, 12:14:16 PM »
Looking good Martin! I like your woodwork on the lower fuselage/wing.
« Reply #52 on: January 19, 2015, 10:19:10 PM »
Thank you for your compliments Dan and Rick.
« Reply #53 on: January 21, 2015, 07:39:37 AM »
The new wing ends are cut off. The ailerons must be still cut.
Mg-belt box finished and front upper cover continued.
Cockpit floor a large part is ready.
The control stik is anew built up, as well as the aileron steering.
« Reply #54 on: January 28, 2015, 09:13:14 AM »
The Cockpit floor is compleet ready with control stick, aileron steering, control wires and belts.
The mg`s are in work.
« Reply #55 on: January 28, 2015, 10:50:51 AM »
Martin,
    You are really doing great detail work here, and also on the parallel D.IV Build. Like Patrick I wonder if you ever sleep! Very nice work, and always so very enjoyable to follow your progress.
Offline dtomko
« Reply #56 on: January 28, 2015, 12:50:08 PM »
Very nice work on the details, Martin.
Drew
« Reply #57 on: January 29, 2015, 12:26:18 AM »
Thank you for your compliments Lance and Drew. :P
Offline BigBlue
« Reply #58 on: January 29, 2015, 08:08:57 AM »
Looks great, Martin!
« Reply #59 on: January 29, 2015, 08:14:14 AM »
Thank you very much Chris.
