Completed models
WNW Fokker E1 : My first WW1 model for publication
Topic: WNW Fokker E1 : My first WW1 model for publication (Read 4295 times)
Inverted
Newbie
Air Traffic Controller, Modeller and aviation geek
December 15, 2014, 07:25:17 PM »
its been a while, sorry for that! Well here she is, my first WW1 build. Lovely kit. I must make a start on the other WNW in the stash! Some of you may have seen her in the latest issue of SAM?
Welcome To My Sky
stefanbuss
Re: WNW Fokker E1 : My first WW1 model for publication
December 15, 2014, 08:18:19 PM »
I like that Little Fokker of yours, especially the squiggles on the metal parts? Did you do them as WNW proposes?
Stefan
PrzemoL
December 15, 2014, 10:41:34 PM »
It was a good pick for the first WW1 kit! With a fine final result, we must admit! Congratulations. And now go for something with more wings and more cables.
Ssasho0
December 16, 2014, 12:07:21 AM »
Excellent Eindecker! Congratulations on a job well done
Think globally, act locally!
December 16, 2014, 12:14:03 AM »
Very nicely done! The weathering on the fuselage is very convincing.
Nigel Jackson
December 16, 2014, 03:52:16 AM »
Very nice work indeed, Eindekker. The first of many more I hope.
lone modeller
Reply #6 on:
December 16, 2014, 04:18:15 AM »
Wonderful model with excellent finish on the nacelle. That is really something to be proud of.
ermeio
Reply #7 on:
December 16, 2014, 05:44:08 AM »
It is really nice!
Well done, keep building
Des
Reply #8 on:
December 16, 2014, 06:23:56 AM »
Your first WW1 model aircraft build, hard to believe it is your first, the result is spectacular, well done and I look forward to seeing many more WW1 aircraft models coming from your bench.
dr 1 ace
Reply #9 on:
December 16, 2014, 06:45:26 AM »
Dittos to the above, Nicely done !
Ernie
"Once more into the breach"
Reply #10 on:
December 16, 2014, 08:29:37 AM »
Great Eindecker, Chris! The weathering on the fuselage is really
well done. Could you give a quick explanation of how you did it?
Beautiful job on your hopefully first of many of that era.
Ernie
WarrenD
Guest
Reply #11 on:
December 17, 2014, 11:05:33 AM »
Well done sir!
Inverted
Newbie
Reply #12 on:
December 17, 2014, 09:34:43 PM »
Hi All,
Thanks for the comments. The finish on the cowlings were as per WNW's recommendations, but with some alteration on the colours. Alclad as a base then with handprinted squiggles using Mr Color. The weathering was using trusty oil paints. Undiluted spots added to the areas to be stained, then worked into the paint with a brush slightly dampened with white spirits. Work until you get the
desired effects. In my opinion, oils are a hugely underrated weathering medium, yet they are so versatile. So much cheaper than the aftermarket weathering based products as well!
Welcome To My Sky
drdave
Reply #13 on:
December 17, 2014, 10:34:11 PM »
Bit nice!
Epeeman
Reply #14 on:
December 18, 2014, 04:36:59 AM »
First WW1 model aircraft - wow!
Spectacular result, well done!
Completed models
