Author Topic: Bristol F-2b Fighter Wingnut Wings 1/32  (Read 9032 times)
Offline gruson
« on: December 10, 2014, 09:49:59 PM »
Hello,
Time to build the Roland C.II WnW kit.
I show you a montage which is nearly finished, the Bristol F-2b
The realisation and painting of the cockpit is more than pleasant because it is particularly precise and complete. Most of the elements are painted « wooden style ».
The engine is then painted with the different coulours recommended by the userguide, and dirtied with dark pigments and brown wash.
The XF 68 colour was suggested by the userguide but I chose to use it mixed with a little brun/rouge XF 10. It’s generously sprayed on the whole kit. Then, so as to nuance the colour, reliefs have been sprayed with this same tint lightened with XF 26, whereas « shaded » parts are sprayed with a mix darkened with green/black.
The extrados is painted with a layer of XF 55 whose plain effect is reduced, with highly diluted white applied on the veins. On the contrary, the hollows are darkened with XF 52, to strengthen the reliefs.
The decals can be applied. Number 12, the tailfin and the wings cockades are made with stencil, once again to nuance the tints.
The second phase of the painting can start again. As I decided to highlight the reliefs of the structure at the back of the fuselage, I began a lengthy and tedious task of masking, using masking tape which can be repositionned at will. This task will consist in light and well-targeted spraying along the masking tape, which had been wisely positionned. I started with XF 55 spraying on the higher parts, which are actually the most exposed to light. Conversely, all the lower parts are darkened with very slight veil of X19 along the masking tape, hiding now the previous light spraying.
Soon
michel
Je suis Charlie
Offline Ian from Doncaster
Re: Bristol F-2b Fighter Wingnut Wings 1/32
« Reply #1 on: December 10, 2014, 09:56:34 PM »
Excellent!!!
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #2 on: December 10, 2014, 09:57:42 PM »
another excellent build! Keep those updates coming
Think globally, act locally!
« Reply #3 on: December 10, 2014, 09:58:04 PM »
Excellent work, Michel!  The paint work is really well done,
especially the wood effects and shading.  Excellent job on
the engine as well.  I look forward to the next update. :)
Offline drdave
« Reply #4 on: December 10, 2014, 10:54:46 PM »
Lovely, especially the engine
« Reply #5 on: December 11, 2014, 01:07:17 AM »
I agree with everything Ernie has said! Beautiful work all around!
« Reply #6 on: December 11, 2014, 03:15:34 AM »
Stunning work about the kit.
Offline Dol
« Reply #7 on: December 11, 2014, 07:35:27 AM »
I like the engine, so dirty   :P
« Reply #8 on: December 11, 2014, 08:37:22 AM »
I never tire of seeing builds of my favourite aircraft, especially one as accomplished as this Michel.
« Reply #9 on: December 11, 2014, 08:53:25 AM »
Beautiful work so far Michel, the wood is extremely well done as is the cockpit and engine, your shading is also exceptional.
« Reply #10 on: December 11, 2014, 01:54:01 PM »
Truly extraordinary work, Michel!  She's going to be spectacular when finished.
Offline eindecker
    • Models In Scale
« Reply #11 on: December 11, 2014, 02:11:27 PM »
Another example of how we learn something here every day. Your paint work is outstanding — really looks like weathered fabric. I am looking forward to another lesson!
Michael Scott
Offline gruson
« Reply #12 on: December 11, 2014, 10:03:56 PM »
Many Thanks  ;D
Soon
Je suis Charlie
Offline IFF1418
« Reply #13 on: December 11, 2014, 10:12:16 PM »
Hi Michel,
Tremendous build again. You are quite a painter aren't you. And your engine is , like others said magnificent. This is going to be a stunner!
Kind regards
Patrick
« Reply #14 on: December 12, 2014, 01:00:31 AM »
   Beautiful work so far Michel. I've built this Kit and can certainly appreciate the impressive quality you've achieved here. Your cockpit is simply stunning!
