Author Topic: WNW Re.8 "Harry Tate" WIP update 30/12/2014  (Read 34992 times)
Offline DannyVM
Re: WNW Re.8 "Harry Tate" WIP update 30/12/2014
« Reply #90 on: April 06, 2015, 05:56:52 AM »
Today, i finnished cleaning the most of the components before priming. Some part's where a little brought up to life and realism.
All part's where lay down to a piece of A4 paper sheet with the proper numbers for recognition.
Some part's where a little enhanced regarding the look and realism. First thing to do was the square holes at the back of the fuselage, where the steering cables passed. For this, WNW provided some PE, but in my opinion, the PE is a little to thick, so i used for the upper square holes some paper tape. For the square holes at the side, i allready used the PE, so i let it be.
On the horizontal stabelizer, upper side are two tubes installed to guide the steering cables. WNW provide this as two solid (bloc's, pin's....) i don't really know how to call them. I cutted these two and replaced them by two brass tubes.
The Vickers gun in the kit is a nice part that is very usefull, still, some extra detail can make the difference.
The busy end of the barrell isn't really very realistic, so some 15 minutes of work was needed to give it another appearance.
The barrell was drilled out, and a little piece of brass tube was installed. Together with some PE, this Vickers became a more realistic kit-part.
I couldn't resist, so i dry-fitted the Vickers gun on the fuselage, this beast got his teeth, but still.....before it's usefull, there's a long way to go.
And finnaly, the landinggear, i glued it together and dry-fit it to the fuselage for a proper alligment.
That's all for now folk's.
Greetz
Danny
« Reply #91 on: April 06, 2015, 07:30:49 AM »
Great work to that parts Danny.
WarrenD
« Reply #92 on: April 06, 2015, 09:00:36 AM »
It's looking great Danny.
« Reply #93 on: April 06, 2015, 09:17:47 AM »
You are doing an excellent job with this model Danny, the machine gun looks amazing.
Offline BigBlue
« Reply #94 on: April 06, 2015, 09:53:57 AM »
Continues to look great, Danny.
« Reply #95 on: April 06, 2015, 11:27:36 AM »
Excellent!
« Reply #96 on: April 06, 2015, 12:38:47 PM »
Terrific work on the modifications! Looking great!
Offline Pgtaylorart
« Reply #97 on: April 06, 2015, 02:09:49 PM »
Great work on the RE8!
George
« Reply #98 on: April 06, 2015, 05:45:07 PM »
Lovely Danny,
Such a shame the RE8 has sold out!
Looking forward to seeing yours progress    :D
« Reply #99 on: April 06, 2015, 10:13:53 PM »
I am really in awe of your work, Danny! It is a shame that the
Re.8 is sold out but at least these examples of your talents can
be put to use on any other models.  You are putting on a great
clinic with this build, my friend,  and I am looking forward to the
next updates. :D
Offline DannyVM
« Reply #100 on: April 07, 2015, 07:26:04 AM »
Thank's very much guy's for you're very nice comment's, this is much appriciated ;) ;) ;)
Today i did some priming work on the Harry Tate part's.
Now it's time to search for the proper colors.
Some proof that priming before painting is always a good thing.
Some scratches and some sink's where detected.
After some sanding and filling the scratches and sink's all seems very fine.
The Vickers machinegun.
Greetz
Danny
Offline KitRookie37
« Reply #101 on: April 07, 2015, 02:57:15 PM »
Hello gentlemen,
Very good idea to sort out parts in paint waiting.  ;)
Best regards.
Alain.
Use the force, Luke.
Offline DannyVM
« Reply #102 on: April 12, 2015, 06:01:50 AM »
Thank's Alain ;)
Today i've airbrushed the propellor and the wing struts.
For the base color i used for both propellor and wing struts Tamiya XF-78. Regarding the wood-grain color i used for the propellor Burnt Umber and for the wing struts Raw Umber.
To make my choice of wood-grain color a little bit easy, i made a sort of a color chart, based on two different base colors and 4 oil colors. For this i used pieces of plastic cart.
Base colors are : Tamiya XF-59 Dessert Yellow
                            Tamiya XF-78 Wooden Deck Tan
Oil colors are : Transparant oxide yellow
                        Burnt umber
                        Raw umber
                        Van Dycke brown
This gives me 8 different wood-grain colors of wich i can chose from, and it look's like this:
OK, time to give the propellor some color.
Base color XF-78
and with the wood-grain color Burnt Umber
Wings struts with base color XF-78
And with the wood-grain color Raw Umber
Greetz
Danny
WarrenD
« Reply #103 on: April 12, 2015, 06:54:56 AM »
Most excellent Danny!
Offline Pgtaylorart
« Reply #104 on: April 12, 2015, 07:55:59 AM »
Your wood is looking great! I like your systematic approach to color mixing for the different wood textures. It would be very informative to see your photo labeled with the specific color combination for each chip shown, if that's possible. :)
George
