Author Topic: DFW C.V (Av) 287/18  (Read 11779 times)
Re: DFW C.V (Av) 287/18
« Reply #45 on: July 04, 2015, 12:46:03 PM »
Stefan,
    Wonderful Model, the paint work and detailing are superb! Best wishes for quick, painless, and quickly recovered surgeries, you'll be back here before you know it!
« Reply #46 on: July 04, 2015, 01:31:50 PM »
Very nice Stefan.
« Reply #47 on: July 04, 2015, 02:19:26 PM »
your model looks gorgeous so far. i relly love the dfw c.v its a beautiful aircraft
Offline stefanbuss
« Reply #48 on: April 18, 2016, 05:29:10 PM »
Friends,
after a break of nearly 10 months work has restarted (Hey, Bo, you are not the only one!) with repairing the undercarriage's rigging, which broke while storing the kit away last year
The generator has been connected to the interior as well.
Completing the tail's rigging will be next
but this will take time. My dexterity has worsened last year (this is now more or less on par with my bad eyesight), which makes it very very hard to insert the rigging into those poly tubes. But Bertl's way of showing those splices is much more impressive than using brass tubing, which means I do have to preserve...
Small progress, I know, and the lack of speed is depressing. I will do my best to speed up.
Stefan
« Reply #49 on: April 18, 2016, 05:53:09 PM »
Hello,
sadly I found that post just right now: Great project, I love the DFW and have one in my stash. It's coming together prettily and from now I'll follow closely!
Borsos
Offline rhwinter
« Reply #50 on: April 18, 2016, 06:11:39 PM »
Yes, good to have you back with the DFW C.V!  Underestimated plane - probably because neither Richthoven nor Voss nor any other adored hero gained air-victories with it...
Offline UFAG
« Reply #51 on: April 18, 2016, 07:46:43 PM »
Remarkable, very nice...!!
« Reply #52 on: April 18, 2016, 09:55:41 PM »
Nice progress Stefan.
A little hint with the polyimide tubing -- run a .25mm (or .30mm depending on tubing size) drill bit thru your little sleeve after you've cut it. Makes it much easier to thread.
« Reply #53 on: April 18, 2016, 09:58:38 PM »
Good to have you back with the DFW, Stephen!  Not to worry about
slow progress...I move at a Snails pace these days too.  The
undercarriage is looking quite fit now and I look forward to the next
updates, my friend.
« Reply #54 on: April 18, 2016, 10:56:24 PM »
   Great to see you active with this one again Stefan, and remember "slow and steady wins the race"! Keep those updates coming, it's looking very nice. :)
« Reply #55 on: April 18, 2016, 10:58:14 PM »
updates, my friend.
Yes, good to see you back on this. As for a SNAILS PACE I think I hold the Title... with the exception of Bo the Magnificent because of his many and varied projects and SUPER DETAILING!
Offline BigBlue
« Reply #56 on: April 19, 2016, 07:26:24 AM »
No prizes given for speed!  Undercarriage looks good.  Glad your are back at the bench.
Offline stefanbuss
« Reply #57 on: April 27, 2016, 02:19:31 PM »
Small update: i successfully finished rigging the tail. This tiny task took nearly eight months, and as it's result is rather negligable, i decided not to bother you with photos.
Stefan
Offline stefanbuss
« Reply #58 on: May 01, 2016, 11:24:53 PM »
Weathering the DFW has begun
I am going for an airframe that had been standing outside for too long. The photos of the aircraft after capture show a rather bleached paintjob, covered with smears on the tail, bad ribtape-repairjobs and a large amount of degradation/abuse.
Lower left wing has a combination of streaks, "hairspray method" (degradation of reinforced area near wingroot) and sponge application for tread marks on the wing area.
S.
« Reply #59 on: May 02, 2016, 12:41:04 AM »
Stefan,
    I like the weathering you are doing here, very nicely done. I prefer a weathered finish on these aircraft and this one, being bleached and somewhat neglected, is a perfect subject. This is looking very nice, keep up the great work!
