Author Topic: Salmson 2-A2 (1/32, Wingnut Wings)  (Read 17970 times)
Re: Salmson 2-A2 (1/32, Wingnut Wings)
« Reply #90 on: December 07, 2014, 10:21:31 PM »
Prze, I am stunned by the beautiful attention to detail in
the painting and weathering of this gem.  Wonderful pictures,
and an even better aid for those of me without your eye for
detail.  Looking forward to the next update, my friend. :)
« Reply #91 on: December 07, 2014, 10:23:21 PM »
Prez,
An absolutely BEAUTIFUL paint job! The shading is subtle but highly effective! Like Ed said even the black! How do you manage to shade the black so effectively?
Offline jknaus
« Reply #92 on: December 07, 2014, 10:47:03 PM »
Fantastic work. Just fantastic. Really coming along nicely.
James
Offline stefanbuss
« Reply #93 on: December 08, 2014, 06:38:16 PM »
Dear Przemol,
are you now fully converted to the larger scale, or will you switch back to your 1/72 jewels after this one is finished?
Stefan
« Reply #94 on: December 08, 2014, 11:58:19 PM »
Prze,
    Magnificent paint work and superb detail as we've come to expect from your bench. This is going to be another stunning model, I'm looking forward to seeing the final photos soon.
« Reply #95 on: December 09, 2014, 12:17:16 AM »
Hello Prez:
You are doing an outstanding job on this very challenging model.  I especially like your approach to the elevator bracing on the underside of the elevator.  Not an easy task and yours looks great.  The paint job is very convincing and looks equally outstanding.  When I did mine, I used EZ line for the wing rigging and left the struts off.  When the rigging was done, I popped the struts in without any problems.  Looking forward to seeing you work through the build.
« Reply #96 on: December 09, 2014, 01:34:09 AM »
Simply stunning Prze! In particular, your wheel covers and rib shading are exquisite. Your Salmson leads the way.
Online PrzemoL
« Reply #97 on: December 09, 2014, 02:57:41 AM »
Thank you, everybody for your nice comments.
... Like Ed said even the black! How do you manage to shade the black so effectively?
It is an easy trick, Rick. The black is actually not black but a very dark grey (black lightened slightly by a mid grey). Then shading with clear-black mix gives a nice contrast  :)
... are you now fully converted to the larger scale, or will you switch back to your 1/72 jewels after this one is finished?
Not fully, Stefan. I try to divide my modelling time between 32nd and 72nd. My recent builds were small Albatros D.II and Bristol Scout. After the Salmson I will probably build two more large ones (Felixstowe!!! :D). But then will be time for the brand new HRModels Pup and Choroszy FE.8.
Mark, actually I had to make two attempts to the underside rigging. Originally I inserted Bob's eyelets to the holes prepared by WNW - inboard of the disk-like detail popping up from the tailplane surface. But then it turned out that rigging to them was impossible, the struts stood in the way. After some deliberation I decided to cheat a bit and drilled new holes outboard of those disks and inserted new four eyelets. Then it was possible to circumvent the struts.
Mark, I will not use EZ line, for the large scale I prefer structural rigging, made from the fishing line. So the struts will go first, then the upper wing and finally I will stiffen the structure with the cables. Photos will come soon... :)
Just after yours, Chris, just after yours. ;)
But many thanks, for your appreciation!
« Reply #98 on: December 09, 2014, 03:16:05 AM »
Just dropped in to catch up on this as I have not looked recently. I simply cannot believe that this is a plastic model - the painting is just so realistic that I had to look twice and then again…. This is a truly wonderful piece of artwork, never mind the modelling!
Michael Scarborough
« Reply #99 on: December 09, 2014, 03:34:27 AM »
Wow.....I keep going back to the wheel covers.....really, really subtle but so believable. Congrats!
Michael
« Reply #100 on: December 09, 2014, 03:50:41 AM »
I missed the last update -- it truly looks superb Przemo
« Reply #101 on: December 09, 2014, 06:23:58 AM »
Exellent painting.
« Reply #102 on: December 09, 2014, 06:40:56 AM »
Exceptional paint work and weathering, this is turning into a real gem.
Offline Epeeman
« Reply #103 on: December 09, 2014, 07:06:21 AM »
Prez -
Your usual impressive work, mate - great weathering too.
« Reply #104 on: December 09, 2014, 08:03:06 AM »
Truly wonderful, Prez  ;)
A pleasure to behold.
