Author Topic: My base under the model  (Read 5102 times)
Offline Jacek
« on: October 03, 2014, 01:55:48 AM »
In this topic I would like to share how I make the basis for model.
I'll start with the final cut and painted plank :
Now assemble the grid to connect plasterboard, in order to enhance the adhesion of glue:
Paper tape mask the edge of the stand:
To forming grounds I use glue for bonding Styrofoam facade panels (glue prepare by adding water into it  :D)
The formation of the land (no need to rush, glue dries long):
Take off the mask and wait for until completely dry:
The next steps are, painting, planting grass and execution of trees and shrubs
To be continued....
Re: My base under the model
« Reply #1 on: October 03, 2014, 09:13:32 AM »
Cool , I'm really looking forward to this . What type of glue are you using ?
Offline Jacek
« Reply #2 on: October 03, 2014, 04:42:57 PM »
I use glue for bonding Styrofoam facade panels.
Offline Jacek
« Reply #3 on: October 05, 2014, 01:17:18 AM »
Successive stages of painting:
I used Humbrol no:  33, 29, 98, 103, 83, 80, 117, 225
The next step: grass, sand and ground.
« Reply #4 on: October 06, 2014, 03:22:22 PM »
great work
« Reply #5 on: October 06, 2014, 03:37:20 PM »
Thanks Jacek for showing us your step by step techniques, I'm sure that many of the members will follow your lead and make similar bases.
Offline Jacek
« Reply #6 on: October 07, 2014, 02:25:44 AM »
Thanks ALBATROS1234 and  Des.
Today, earth and sand.
I take Earth from the garden, drying and sieving through a fine strainer.
The sand is from a piece of sandstone found on the river.
To be continued.... :D
« Reply #7 on: October 07, 2014, 07:00:51 AM »
Very great, waiting for the next.
Offline Jacek
« Reply #8 on: October 09, 2014, 01:17:30 AM »
Planting grass.
Materials needed for grass and leaves.
At the beginning of the grass dry and ruined:
Offline Umlaufmotor
« Reply #9 on: October 09, 2014, 04:34:35 AM »
GREAT!
For me, an excellent tutorial - I'm a total idiot in terms of make a diorama :-\
How and with what typ of glue you attaching the grass on the plate, Jacek?
Servus
Bertl
Offline Jacek
« Reply #10 on: October 09, 2014, 04:44:55 PM »
Watching your models I think that is not quite a true ;)
I use wood glue. It is water based and easy for me to control its density, when it is wet is white, and when dry becomes clear.
Offline Jacek
« Reply #11 on: October 11, 2014, 12:32:00 AM »
Dark green grass :
The rest grass and clumps of grass:
Next, tree and bush.
Offline Jacek
« Reply #12 on: October 15, 2014, 01:52:31 AM »
Tree and bush.
Materials needed to be done a tree:
Thorny pigweed (Teloxys aristata)
The leaves.
With pieces of toilet paper and glue we form the tree trunk and branches:
With bush we act similarly:
The next: painting tree.
« Reply #13 on: October 15, 2014, 06:56:47 AM »
The application of the grass has certainly made the base come to life, and it has been a real treat watching you form the tree and shrub, I'm looking forward to seeing paint added to the tree.
Offline Jacek
« Reply #14 on: October 18, 2014, 02:04:19 AM »
Painting.
The first color Humbrol 82.
Next the color of Humbrol 80, 150
At the end of a very much thinned black.
Next leaves.
