Author Topic: Curtiss Hydroaeroplane  (Read 60851 times)
Offline sobrien
Re: Curtiss Hydroaeroplane
« Reply #30 on: October 11, 2014, 12:31:50 AM »
Beeyoooteefulll! Des, your going to have to do a tutorial on making these brass bits. They are lovely.
Sean
« Reply #31 on: October 11, 2014, 03:34:54 AM »
You scratchbuilders bring joy to my aging eyes - long may that continue  ;)
Excellent work, Des.... but you already know that!
« Reply #32 on: October 11, 2014, 05:18:38 AM »
Your scratch is awesome, Des. Your detailing is so great.
« Reply #33 on: October 11, 2014, 09:53:18 AM »
Hey Des , Thumbs up !
Did you use solder on the column or just super glue ? I always wanted to try soldering . Some parts are better made with brass and easier than using plastic rod .
« Reply #34 on: October 11, 2014, 10:31:36 AM »
Thanks Terri - I used super glue on the control column but since I have had a soldering station stashed away for two years I thought I would get it out and try to solder. I did the small upright diamond shaped piece holding the engine beams and the soldering worked well, so from now on I will be doing most of the brass work using solder. I purchased some low heat soldering wire and some really good no mess no clean-up flux, so this makes the job really easy.
« Reply #35 on: October 11, 2014, 11:33:45 AM »
I'm a little late to the party, Des, but as usual, you are off to a  great start. :D
I'm a fan of your work and look forward to following this one.
« Reply #36 on: October 12, 2014, 07:00:49 AM »
Stunning work as always Des. You make even the most difficult tasks look easy: please, how do you do it?
« Reply #37 on: October 16, 2014, 11:49:13 AM »
Thanks for the reply Des , this weekend I will be looking more into this .
« Reply #38 on: October 16, 2014, 04:35:57 PM »
Des, it is another masterpiece of yours in the making. I will be watching this thread with a great excitement, as usual.
« Reply #39 on: October 16, 2014, 06:06:51 PM »
A trial fit of the twin seat assembly. The framework around the seats is the aileron actuating mechanism, it is controlled by the pilot leaning his shoulders on the frame and pushing the frame in the direction he wishes the aircraft to turn. The two small pedals on the foot bar are the throttle pedals, one for each pilot.
« Reply #40 on: October 16, 2014, 07:27:59 PM »
Your usual STUNNING work Des! The seats are beautifully rendered!
« Reply #41 on: October 16, 2014, 10:23:30 PM »
Wow so beautiful Des. ;D
Offline Jacek
« Reply #42 on: October 17, 2014, 12:18:20 AM »
Fantastic work !
I reserve the first flight  :D
Jacek
Offline ondra
« Reply #43 on: October 17, 2014, 02:15:59 AM »
Des, I took about two days to think about what to reply on the pics you have posted.
Eventually, the only words that come to my mind are: You are a master modeller and many thanks to you for sharing your WIP with us. I really admire the perfectionism and craftsmanship you are showing here.
Ondra
« Reply #44 on: October 17, 2014, 02:23:48 AM »
I agree with everything Ondra has written +10.
