Under Construction
Scratch builds
Curtiss Hydroaeroplane
Pages:
4
5
6
7
21
Topic: Curtiss Hydroaeroplane (Read 61008 times)
Royston
Full Member
Re: Curtiss Hydroaeroplane
Reply #60 on:
October 21, 2014, 09:28:07 AM »
Wonderful work there Des of an unusual subject. i shall look forward to your next installment with eager antisipation.
Roy
Dave W
Reply #61 on:
October 21, 2014, 12:02:37 PM »
Another masterpiece Des. You continue to raise the bar on historic aircraft modelling.
Des
Reply #62 on:
October 22, 2014, 08:00:30 AM »
Many thanks to Martin, Ernie, Dagmar, Nigel, Roy, David and Bo for your very nice comments.
Just a small update this time, I made the radiator, it is made from styrene sheet and I used RB Production PE radiator wavy mesh, great product but very hard to cut. The strap running around the bottom and half way up the sides of the radiator is made from thin coke can metal. I also made the two engine bearers.
Reply #63 on:
October 22, 2014, 08:46:45 AM »
Sweet!
Nough said!
coyotemagic
Reply #64 on:
October 22, 2014, 10:24:23 AM »
Extraordinary, Des!
Des
Reply #65 on:
October 22, 2014, 10:40:45 AM »
Thank you Bo, Rick and Bud, your comments are very much appreciated.
lcarroll
Reply #66 on:
October 22, 2014, 11:39:49 AM »
As usual, Des, simply superb. The Radiator is wonderfully clean for a scratch Built component of metal and plastic. I marvel at your incredible detailing, just a joy to follow your progress.
PrzemoL
Reply #67 on:
October 22, 2014, 05:11:48 PM »
It looks absolutely real, Des!
bobs_buckles
Freedom isn't free.
Reply #68 on:
October 22, 2014, 05:29:35 PM »
Quote from: PrzemoL on October 22, 2014, 05:11:48 PM
+1
Beautiful
vB
Des
Reply #69 on:
October 22, 2014, 05:36:27 PM »
Thanks to Justin, Lance, Przemol and Bob for all your wonderful comments, they are very much appreciated.
ondra
Reply #70 on:
October 22, 2014, 07:48:49 PM »
Has anyone seen my jaw?!? Must be somewhere on the floor.
Perfect work, Des.
Ondra
radio
Reply #71 on:
October 22, 2014, 11:33:44 PM »
Very well work for these details.
Last Edit: October 23, 2014, 03:26:54 AM by radio
lone modeller
Reply #72 on:
October 23, 2014, 01:17:09 AM »
Quote from: ondra on October 22, 2014, 07:48:49 PM
Mine fell off completely. That looks soooo real I cannot believe it.
Des
Reply #73 on:
October 23, 2014, 10:41:34 AM »
Thanks to Ondra, Martin and LM for your very kind comments.
I made and added the engine hand crank assembly. This was mounted ahead of the radiator and the drive shaft passed through the radiator to connect to the engine, I made the frame and the crank from 0.25mm styrene strips, the handle is made fropm 0.7mm aluminium tube. Apart from a few paint touch-ups the radiator is finished.
Love the self
Reply #74 on:
October 23, 2014, 10:50:02 AM »
Beautiful work Des !
Pages:
4
5
6
7
21
Under Construction
Scratch builds
