Author Topic: Eduards Fokker D.VII 1/48 Jasta 2 Unknown pilot ( spad markings )  (Read 19780 times)
Re: Eduards Fokker D.VII 1/48 Jasta 2 Unknown pilot ( spad markings )
« Reply #45 on: November 25, 2014, 11:08:30 PM »
Thanks guy's  :)
I got the fuselage halves glued up and the seems and ready for paint and decaling . Will post pictures later tonight once the batteries for the camera are charged up .
« Reply #46 on: November 26, 2014, 12:53:18 AM »
I'm looking to tonight's pictures, then Terri. There's a real kick in getting the fuselage sealed up, even if it means losing sight of some of the super work you've done.
« Reply #47 on: November 26, 2014, 02:41:49 AM »
Don't know how I missed this little beauty, T!  You're off to a brilliant start.  Outstanding cockpit work.
Offline kornbeef
« Reply #48 on: November 26, 2014, 02:56:01 AM »
See it doesnt have to be 1/32nd or WNW to look most excellent but.....
Wot no cat hair? ::)
Keith ;D
« Reply #49 on: November 26, 2014, 11:21:48 AM »
Wow , thanks guy's . I'm really touched  :) The cockpit did turn out rather well and I'm not liking those per painted PE parts by Eduard . The instruments are nice though and very useful . Decals can be a pain at times .
Keith , message from Blau . She is finished yet ......
Fuselage button up , seems clean up and polished , lower lacing replaced . The kit part was broken and a missing the part that broke off . I filled this in with some scratch stock and the lacing is from Eduards PE line .
« Reply #50 on: November 26, 2014, 11:22:21 AM »
« Reply #51 on: November 26, 2014, 11:23:21 AM »
So why stop there , have to test fit the lower wing
« Reply #52 on: November 26, 2014, 11:27:22 AM »
I started doing this a long time ago and found it to be a saver in time and handling . Before I would always cut the rudder free which lead to doing one side at a time . In the end this is handling it more , perfect for that extra time for a finger print or glue make even a cat hair has the chance of working it's way in there . Now I leave it attached making my life easier ! Only clean up afterwards is the same attachment point .
« Reply #53 on: November 26, 2014, 11:36:48 AM »
Terri,
Looking outstanding with it all buttoned up!
« Reply #54 on: November 27, 2014, 07:34:03 AM »
Realy good work Terri.
« Reply #55 on: November 27, 2014, 10:41:54 PM »
Thanks guy's , this weekend I will be able to start spraying some colour and start the decaling .
« Reply #56 on: December 08, 2014, 12:39:24 PM »
With folks leaving me alone this weekend I was able to get a fair bit of airbrushing down done this round at the bench .
Basically everything got a coat of white . For this I used Tamiya flat white thinned with Tamiya lacquer thinner . While this was drying the guns were assembled and sprayed black as well as the half portion of the tail feathers . Tamiya black thinned as above .
While all this was drying I mixed up a bit of purple using Tamiya paints spraying the center of the wheels . Up next was the dark green being applied to the fuselage , axle wing , out part of the wheels and all the strut's which aren't picture .
I sprayed the prop Tamiya deck tan and already has two coats of clear in prep of the wood lamination decals in the kit . I never tried using decals for this so it is more out of my own curiosity .
Pre-shading on the fuselage I did with Tamiya smoke . This is where I leave off for now while I clear coat now in prep of the lozenge decals .
« Reply #57 on: December 08, 2014, 12:39:55 PM »
« Reply #58 on: December 08, 2014, 12:40:23 PM »
« Reply #59 on: December 08, 2014, 12:41:18 PM »
