Author Topic: 1/32 Albatros W.4  (Read 17766 times)
Re: 1/32 Albatros W.4
« Reply #60 on: September 01, 2014, 06:46:42 AM »
A very good wood grain and build until now.
Offline Dagmar Henderickx
  • Slow Builder
« Reply #61 on: October 05, 2014, 08:37:27 PM »
Dear colleagues,
Alright, finally back to the modeling table again!
As warming up, continuation of preparing the basis for creating the wood effect of the other internal 'wooden' parts. I used the same color combination as for the upper part of the cockpit compartment.
Next, start of building the floats. Using plastic card of different thickness, the first steps of the build look promising I think.
Till next time,
Dagmar
« Reply #62 on: October 05, 2014, 10:08:56 PM »
Nice to see this back on the board; the floats look great. Good work takes time, this should be a real winner!
« Reply #63 on: October 05, 2014, 10:34:52 PM »
The floats look awesome! Did you cut the shapes and then just bend them together and reinforce with the formers visible?
Offline jknaus
« Reply #64 on: October 06, 2014, 01:16:16 AM »
Very very cool stuff.
James
Michael Scarborough
« Reply #65 on: October 06, 2014, 11:11:36 AM »
Really wonderful stuff.....excellent work, Dagmar!
Of course, you going to all the trouble of this conversion is one way to be sure that WnW will announce a W.4 for C'mas!
I look forward to your posts and hope you will keep them coming.
Cheers from NYC,
Michael
  • Slow Builder
« Reply #66 on: October 07, 2014, 04:21:43 AM »
Dear colleagues,
Thanks for the kind words!
Hi Rick, indeed, I took the top of the floats as basis for the build and glued both sides, cut into shape to it. The formers should strengthen the whole thing and also make sure that both sides are perpendicular to the top of the float.
Hi Michael, you are just describing the worst nightmare when you're building a conversion...
Till next time,
Dagmar
Michael Scarborough
« Reply #67 on: October 07, 2014, 11:35:36 AM »
Have you seen the really wonderful 1/32 Beached Walfisch diorama by Per Olav Lund? He scratch built and vac-formed a gorgeous Roland Walfisch and I think he did so less than a year before, Voila, WnW released not one, but TWO, gorgeous kits of the same plane.
Yes, that is the nightmare! So, I guess this means you are the sacrificial lamb, Dagmar! Just when you finish this gorgeous conversion, WnW will announce their brand new ALBARTOS W.4! We all thank you in advance!
In the meantime, keep up the good work!
Cheers from NYC,
Michael
PS Truthfully......as much as I wish they would do a W.4, I hope this doesn't happen to you!!
Offline jknaus
« Reply #68 on: October 08, 2014, 04:05:08 AM »
Fantastic.
James
« Reply #69 on: October 10, 2014, 09:20:07 AM »
Anxiously await next update, great work so far.
Offline jknaus
« Reply #70 on: October 10, 2014, 09:59:28 AM »
You have got me so keen on this build that I just got a card stock model and will attempt to use it to make this conversion. Eagerly looking forward to more.
James
  • Slow Builder
« Reply #71 on: October 14, 2014, 03:42:02 AM »
Dear colleagues,
The pressure, the pressure... Hope to live up to your expectations  :)
Well, I was able to finalize the floats. After the general shape of the floats was to my liking, the upper part of the floats was detailed with plastic card and Evergreen strips cut in the desired shape and guided by Tamiya tape cut templates.
Finally, tape of different thickness is used to simulate the reinforcements on the edges of the floats.
Till next time,
Dagmar
Michael Scarborough
« Reply #72 on: October 14, 2014, 03:55:32 AM »
Bravo! This is looking great Dagmar! I would say the pressure is not affecting you in the slightest......
Using different widths of tape as a means of a repeated measurement is such an obvious choice.....once one thinks of it! LOL!
May I ask how you are adhering the tape for permanence? I would think that the adhesive that comes on it would not be sufficient for long term sticking.
Cheers from NYC,
Michael
« Reply #73 on: October 14, 2014, 05:49:06 AM »
Awesome work! You are getting close to the point this one will begin to take shape as a Float Plane!
« Reply #74 on: October 14, 2014, 06:02:39 AM »
Very great work.
