Author Topic: 160hp Beardmore engine  (Read 16807 times)
Re: 160hp Beardmore engine
« Reply #45 on: June 30, 2014, 10:55:47 AM »
Thanks very much for all the kind comments, very much appreciated.
Nanks, This engine is from the WnW FE.2b kit and will eventually go into that model, but just for something different I thought I would do the engine first.
Des
« Reply #46 on: July 06, 2014, 10:15:53 PM »
A few more photos with some extra plumbing added to the engine, also the throttle cables and the flexible tacho drive. The two magneto drive gears are watch gears and the ignition leads are braided electrical cables from ear phones.
« Reply #47 on: July 06, 2014, 11:44:05 PM »
Wow, Des!  This is undeniably your best engine yet and the most realistic Beardmore I've ever seen!  Amazing work, mate.  What type of earphones did that wire come from?  I need to get some of that.
guitarlute101
« Reply #48 on: July 07, 2014, 12:18:02 AM »
Now that is some fine detailing Des. Looking forward to more!
Offline LindsayT
« Reply #49 on: July 07, 2014, 01:10:02 AM »
Des, I asked Chris Johnson a while ago about his painting workflow on things like engines with a lot of different coloured fiddly bits (thanks Chris!). I look at examples like his and your work, and there is such a clear and definite demarcation of every detail. Even when I paint parts individually I can't get the resolution that you do. What's your workflow for something like this? Paint all the parts individually then assemble? Assemble then mask and paint? Brush or airbrush? Inquiring minds need to know!
Lindsay
« Reply #50 on: July 07, 2014, 02:26:58 AM »
Simply stunning Des.
« Reply #51 on: July 07, 2014, 02:58:54 AM »
When you fit the fuel lines will it start and turn the propellor as well? Absolutely amazing work. If I had not seen it I do not think that I would have believed it!
Offline stefanbuss
« Reply #52 on: July 07, 2014, 03:20:40 AM »
Absolutely amazing.
The metal parts are near perfect. I envy your skills.
S.
Offline Ronkootje
« Reply #53 on: July 07, 2014, 05:08:50 AM »
My god des nice work like the trottle linkige how did you do that?
Ron
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #54 on: July 07, 2014, 06:02:26 AM »
<--- speechless! Wonderfully wonderfull work Des :)
Think globally, act locally!
Offline Epeeman
« Reply #55 on: July 07, 2014, 06:03:00 AM »
Great work, Des -
Your attention to detail is amazing
« Reply #56 on: July 07, 2014, 09:12:48 AM »
Bud - The earphones are the type that push inside the ear, like ear plugs, very small. They can be found at the $2 shops, the cable is a twin cable which is necessary for the two ear plugs, inside each cable are three strands of the braided wire 0.2mm in diameter, the photos explain it better;
Lindsay - I try to air brush as many parts as possible before assembly, as I use Mr Metal Color metal paints spraying gives a better finish due to it's very fast drying properties. As with all parts I scrape paint off areas where glue is to be applied then I assemble the engine. Any touch-up painting can quite easily be done after assembly. Things like plumbing and electrical wiring are painted after they are fitted as were the spark plugs, the ignition leads are natural wire. I try to leave all the RB Motion brass nuts as natural brass, they stand out better.
Ron - The throttle linkage cables are made from 0.25 brass wire bent to shape then fitted to the linkages, a small brass nut was placed near the lingage then the wire was painted black.
Stefanbuss - The Mr Metal range of metal colours are brilliant, they apply extremely well and dry very fast, they can be left as is or they can be buffed to give a nice sheen to suit your desired look. The paint can be sprayed or brushed but spraying is better.
Thanks very much for all the very kind comments.
« Last Edit: July 07, 2014, 09:49:41 AM by Des »
Offline LindsayT
« Reply #57 on: July 07, 2014, 09:47:34 AM »
Beautiful. Thanks very much for the explanation.
LT
« Reply #58 on: July 07, 2014, 09:53:21 AM »
Please excuse the quality of the previous photos of the engine, I had to use my old camera as the battery was flat in my new camera, a stuff-up on my part  :-[
« Reply #59 on: July 07, 2014, 01:04:28 PM »
Des,
Another fine update showing just how Spectacular your work is!
