Author Topic: cutting thin copper wire without messing up the ends?  (Read 1982 times)
Offline Chuckt5
« on: February 16, 2014, 11:50:42 AM »
I want to cut some soft copper wire that is .3mm in diameter (pretty thin). Normally I would just use a wire cutter to cut it, but the problem with the wire cutter is it leaves the end all crimped and smooshed!
Does anyone out there have a good method for cutting wire this thin that leaves the end relatively square and not sqaushed?
Thanks in advance, chuckT.
Re: cutting thin copper wire without messing up the ends?
« Reply #1 on: February 16, 2014, 11:58:07 AM »
Cut it with a #11 knife using a rolling action like you would cut a tube.
Offline Chuckt5
« Reply #2 on: February 16, 2014, 12:26:10 PM »
Thank you  :)
I was wondering about that.
« Reply #3 on: February 16, 2014, 03:19:27 PM »
yeah what bo said.
Offline Chuckt5
« Reply #4 on: February 16, 2014, 03:43:32 PM »
Thanks.  ;) I also discovered my orange handled Xuron cutters seem to make a nice square cut too!
