Author Topic: 1/32 Sopwith Tabloid, RNAS No. 168, Lt. Marix, Oct. 1914  (Read 50181 times)
« Reply #195 on: September 29, 2014, 06:15:43 AM »
This has been an outstanding piece of scratch building. It looks to be the standard of WNW but is all home made - a real tribute to your skill. I am waiting with anticipation to see it completed.
« Reply #196 on: September 29, 2014, 10:37:28 AM »
Truly enjoyable so far !
For the combing , have you tried using the covering from striped wire ? Works well in 48 scale .
« Reply #197 on: September 30, 2014, 02:55:06 AM »
A wonderful work Bob.
Offline NinetythirdLiberator
« Reply #198 on: October 01, 2014, 03:12:43 AM »
Truly beautiful!  I've been following and lurking but now it's high time to say "Excellent!  Well Done!!!"
Really a model to be proud of...and not often modeled!
Dan
« Reply #199 on: October 01, 2014, 05:56:44 AM »
Beautiful Model and really looks great with the wing resting in place!
« Reply #200 on: October 01, 2014, 09:35:51 PM »
Crisp, clean and so inspiring. Fantastic modelling, Bob.
« Reply #201 on: October 01, 2014, 10:10:33 PM »
Excellent job, Bob.  I have to hand it to you talented scratch-building modellers!
I am looking forward to the next updates.
Offline Old Man
« Reply #202 on: October 02, 2014, 03:05:18 PM »
Now that is starting to look like an aeroplane, Sir!
Excellent work.
« Reply #203 on: October 06, 2014, 09:08:02 AM »
Thanks for the support everyone!  You keep me going when it seems challenging.
Thanks for the tip Terri!  I will give that a try.
There has been progress this week, although it doesn't necessarily show in outward appearance.  The wood toned parts are now complete, although I still have to drill and add the rigging points and eyelets to the undercarriage.  Much time this week was spent on drilling and attaching the rigging eyelets in the fuselage and wings, a somewhat laborious process that doesn't much change the appearance of the model.
Here is the undercarriage with the fittings painted:
The struts are a bit overscale in thickness, but I needed the extra size for strength and rigidity, and I think it looks the part anyway.  Here is a closeup of the axle/bungee area:
The fittings holding the bungees in place are plastic strip and brass rod.  I made the bungees by wrapping thread around two finishing nails appropriately spaced on a scrap piece of basswood, tied up the bungee bundles as shown in period detail drawngs of the axle area, then threaded the brass rod through each end of the bungee  bundle and the drilled out fittings.
I always have a difficult time with getting the interplane struts the correct length, since often my models bear only a passing resemblance to the plans! :o  Actually, it's not that bad, but minor dimensional variance does tend to creep in at various points, and getting interplane strut length to match up with the cabanes is always a bit of a struggle for me.  This time I was smart and borrowed a trick I saw someone use here: I made a test template for the interplane struts by gluing extra plan copies of the side profile showing the interplane struts to index card stock and cutting out the strut area.  This template was then taped to the bottom wing at the correct location and then the top wing was fitted on to the cabane attachment points (brass pins in the cabanes).  It looks like this:
Based on this fitting, I determined that the rear strut on one side was too high, and I trimmed the tremplate to properly match the undersurface curve of the top wing.  Once I got everthing to align well, the templates then served as a measure to trim the struts to proper length.  At least that's the theory.  We'll see if it works as soon as I get the rigging installed in areas where it will be easier to do before the top wing is mounted, by tomorrow I hope. :D
Getting close now! ;D  Maybe I'll actually get this done in time to finish the D.VII Group Build!
« Reply #204 on: October 06, 2014, 10:08:02 AM »
Excellent work on the undercarriage Bob, the wood colour and the brackets look very convincing. Making the templates for your wing struts will prove very useful, well done.
Offline KitRookie37
« Reply #205 on: October 06, 2014, 02:55:09 PM »
Hello to all,
It's looks terribly realistic. Wahou !! Great work ! Congratulations.
Best regards.
Alain.
Use the force, Luke.
« Reply #206 on: October 06, 2014, 03:19:38 PM »
quite a nice update, moving right along eh?
« Reply #207 on: October 06, 2014, 11:45:55 PM »
Beautiful skids! The wing alignment jig looks simple but effective.
« Reply #208 on: October 09, 2014, 12:48:23 PM »
Thank you all for your kind comments.
I wanted to post a progress report today, as it is the centenary of the Dusseldorf Raid.  On October 8, 1914, Lt. Reggie Marix flew Tabloid 168 from his base near Antwerp, Belgium, to Dusseldorf and successfully dropped a 20 lb. Hales bomb on the Zeppelin shed at Lohausen, destroying Zeppelin Z.XI inside, in one of the first long distance bombing raids in aviation history.
Although I was unable to complete this build in time for this milestone, I have managed to get the major airframe components assembled, save the undercarriage, and to complete the interplane rigging.  Here she is, looking more like Tabloid No. 168 on this auspicious anniversary:
One of the things I love about the Tabloid is the clean basic design and elegant lines of the airframe, along with the unadorned CDL finish.  Simple and basic aviation beauty! ;)
The top wing installation went rather painlessly, and the rigging was also fairly simple because of the limited amount, even with double wires, and the ample space between the wings.  I managed to knock of the tail skid while installing the tailplanes, so I will have to fix that.  The only things left, other than the footstep and bombs, is installation and rigging of the undercarriage and rigging the rudder and elevator.  Almost there, 100 years later! ;D
« Reply #209 on: October 09, 2014, 01:18:04 PM »
Your Tabloid is looking fantastic Bob, it really is a beautiful looking aeroplane. You did a superb job with the top wing placement and the rigging, not far to go now before she will be up on her feet.
