Author Topic: 1/32 Sopwith Tabloid, RNAS No. 168, Lt. Marix, Oct. 1914  (Read 49902 times)
Offline KitRookie37
« Reply #210 on: October 09, 2014, 02:54:35 PM »
Hello to all,
I agree with Des. I liket it !!
Best regards.
Alain.
Use the force, Luke.
« Reply #211 on: October 09, 2014, 04:52:26 PM »
Bob,
 What a beauty!  ;)
You must be one proud modeller.
I look forward to seeing her complete.
VB   :)
« Reply #212 on: October 09, 2014, 10:01:59 PM »
Your Tabloid is OUTSTANDING! I also appreciate the History. You came very close to making it for the 100th anniversary!
« Reply #213 on: October 10, 2014, 12:03:17 AM »
   Beautiful work Bob, and a tribute to your talents. You've created a masterpiece here, and I'm looking forward to seeing her on her feet and completed.
« Reply #214 on: October 10, 2014, 05:51:21 AM »
A fantastic work Bob.
« Reply #215 on: October 12, 2014, 06:55:57 AM »
I have been away recently so only just caught up. Another amazing early type - that is a model to be truly proud of. The bungees just look so realistic and the idea for the struts is an excellent one. Thanks for sharing with us.
« Reply #216 on: October 12, 2014, 07:17:01 PM »
Hi Bob
This is one of those builds where I feel that I'm learning so much. Thank you for sharing it all with us.
« Reply #217 on: October 12, 2014, 10:00:37 PM »
Very nice, Bob! The rigging looks great.  Beautiful model, nearing
completion.
« Reply #218 on: October 12, 2014, 10:44:36 PM »
Thanks to all of you for your support. :D
The elevator and rudder are now fully rigged with control wires.  I used EZ-Line for this, as it puts less pressure on the delicate control horns and is easier to get taught without misshaping near the attacment points on these short runs.  The interplane rigging is all monofilament with Bob's Buckles for strength and support, particularly for the bottom wings.
The undercarriage is partially rigged and now cemented in place with CA on the brass pins and epoxy applied carefully with a dental tool to fill gaps.  I used mono to rig the lateral and rear rigging, and EZ-Line for the front cross rigging, since I was not worried about strength, but was concerned about puling the "horns" of the landing skids inward, since there is no lateral support member forward of the axle on this undercarriage, and lateral pressure from rigging lines forward of the axle could tow in (or out) the skids.  I will be using EZ-Line for the wires running from the forward outside edge of the skids to the bottom of the lower wing, for the same reason.
I expect to have the undercarrige rigging completed tomorrow night, and will post some pics then.  Only thing after that is the footstep and the bomb rack and Hales bombs, liberated from a WNW Fee kit. ;D  Speaking of which, I need your help with one point on which I am unsure.
The Fee kits (and perhaps others) indicate a bomb release cable running from the cockpit OUTSIDE the fuselage and underneath to the rack.  I suspect this was the case with the Tabloid, since it was jury-rigged for bombing missions.  However, it is certainly possible that mechanics could have run the cable from the cockpit through the bottom of the fuselage covering to the rack, a much shorter run ( and one which would look much better for display of the model, IMO).  Does anyone have any information or thoughts on this issue?  Since I have no information on this, I may end up just doing what I want. ;)
« Reply #219 on: October 14, 2014, 01:52:38 PM »
She is now on her feet, and only the footstep, bombs and rack need to be added.  Here are some final workbench shots:
I am very pleased with how this one turned out, although it took eight months. ::)  I will add the bombs and footstep and post more pictures over in Completed Models later in the week, assuming the wings don't fall off before then. ;)  Thanks to all of you who have followed along and been so supportive.  On to the D.VII Group Build! ;D
« Reply #220 on: October 14, 2014, 02:48:59 PM »
Congratulations Bob, she is absolutely stunning, you should be very proud of your achievement. I look forward to seeing your last series of photos.
« Reply #221 on: October 14, 2014, 04:30:56 PM »
Very impressive Bob. You are so near to completing what has been a fascinating project.
« Reply #222 on: October 14, 2014, 05:45:05 PM »
What Des said +1
Beautiful work, Bob  :)
vB
« Reply #223 on: October 14, 2014, 07:30:20 PM »
Magnificent work!
« Reply #224 on: October 15, 2014, 12:24:15 AM »
Superb craftsmanship Bob. Simply superb! She's a real beauty.
